ok.. another compression test results question
Old Oct 9, 2002 | 10:40 PM
AccrdATK's Avatar
New User
Default ok.. another compression test results question
i just recently done a comp. test.. results were 195, 200, 205, 205... normal or no? this is on a stock motor with just intake and exhaust...ignition coil fuse out.. and cranking for about 3-5 seconds... didnt open throttle.. was i suppose to? also the motor was i guess semi warm... was sitting for a little bit, any replies will be greatly appreciated
Old Oct 9, 2002 | 11:56 PM
AccrdATK's Avatar
New User
Default Re: ok.. another compression test results question (JdMR-536)
anybody?
Old Oct 10, 2002 | 12:02 AM
Tommy_Gunns's Avatar
You were supposed to floor the gas pedal while you cranked the motor. If you do that, you will get higher numbers.
Your numbers look very normal. As long as the deviation isn't drastic, you are good to go.
Old Oct 10, 2002 | 12:05 AM
Art Vandeleigh's Avatar
Default Re: ok.. another compression test results question (Tommy_Gunns)
you can do the test either WOT or not. but you get higher numbers with WOT. as long as the numbers are not drastically different from each other you are fine. my numbers:
cyl
1----225
2----225
3----220
4----225
jdmcivic2fast
Oct 2, 2011 08:19 PM
drave
Nov 21, 2010 01:55 PM
97civic07gsxr
17
Mar 5, 2009 12:30 AM
ITR RACER
May 24, 2004 03:09 PM
Zorro
Nov 26, 2001 09:42 AM
