wont start after drive
Old Feb 24, 2012 | 07:38 AM
88EFsedan2's Avatar
Default wont start after drive
i can start me ef drive it a little ways then turn it off an it wont start this guy says to spray the fuse box with wd40 an that will fix it has anyone ever done that?
Old Feb 24, 2012 | 07:43 AM
kp's Avatar
kp
Default Re: wont start after drive
If you're looking for a thread lock, you're right on track. Don't be silly. If you have a legitimate problem, just explain it and you'll get help.
Old Feb 24, 2012 | 07:50 AM
jlicrx's Avatar
do you have any codes showing at the ECU?
most probable cause for your problem is a bad Main Relay, but could also be a bad igniter in the distributor
when it isn't starting and you turn the key to the 'on' position, does the Check Engine Light come on for 2 seconds and then go off? when you turn the key to 'on' can you hear the fuel pump priming? - if no, these are symptoms of bad Main Relay - a bad igniter should throw a check engine light with a code 15 (ECU LED flashing 15 times)
stay away from people that say spray your fuse box with anything - this is a sign of someone who doesn't know s**t
Old Feb 24, 2012 | 07:54 AM
88EFsedan2's Avatar
ya after im turning it over an it wont start it comes on but after it starts if goes off i changed the relay an it did good for a few days then did again
Old Feb 24, 2012 | 07:58 AM
jlicrx's Avatar
check for codes at the ECU - the check engine light doesn't need to be on to show codes - once the ECU determines a problem, it stores the code and the code remains until you physically reset the ECU
Old Feb 24, 2012 | 02:18 PM
crvtectim's Avatar
In my mind, I heard that in a leprechaun's voice. Bwahaha
Old Feb 24, 2012 | 02:38 PM
ultrajuan33's Avatar
Most likely the main relay and / or distributor are on their last leg...
ILOVEYOURHONDA
20
Aug 6, 2013 01:06 PM
egcivic
Nov 20, 2006 05:32 PM
EJ1_203
Sep 10, 2006 04:36 PM
6doorsentra
Jul 11, 2006 09:26 PM
irev210
Jun 11, 2003 07:00 PM
