97 Civic front lower motor mount question
Old Feb 24, 2012 | 06:42 AM
bigfinderman's Avatar
Default 97 Civic front lower motor mount question
Sup guys. When i swapped my trans and head on my civic, i bought a new front lower motor mount. The one coming off the front bottom of the engine to the frame. Is the center hole in the mount suposed to be quite a bit larger than the shaft of the plate it slides onto? Theres some slop in it when you have it slid on to the shaft. Thanks
Old Feb 24, 2012 | 09:07 AM
timmytimm3's Avatar
Default Re: 97 Civic front lower motor mount question
It's normal. If you look at the washer it's keyed to fit the flat spot on the stud.
I ran into the same thing.
Old Feb 24, 2012 | 09:11 AM
98civdx's Avatar
Master Detailer
The compliance bushings? Your post makes no sence.
Old Feb 24, 2012 | 09:17 AM
timmytimm3's Avatar
Pretty sure he's talking about this mount
Old Feb 24, 2012 | 09:23 AM
Yea thats the one im talking about. It just didnt seem normal for it to have that much play in it. Thanks
Old Aug 8, 2012 | 06:18 PM
pimp99noma's Avatar
I have found the same thing on my 98 ex y7/y8 build I cant see how that could be right if you look at the first pic in the thread linked below you can see there is 1/8" all the way around the bolt. Why would the be a 1/2" bolt in a 3/4" hole.
https://honda-tech.com/forums/showthread.php?p=47511837
Sean1992
Honda Civic (2006 - 2015)
Feb 2, 2017 02:25 AM
LeonardDB
Apr 28, 2014 06:26 AM
2k3s2k
14
Feb 14, 2014 01:31 PM
RNPoo7
Mar 28, 2007 01:16 PM
IN2VTEC
Jun 26, 2002 03:54 PM
