Transmission & Drivetrain Gearboxes, Differentials, Clutches
Good tutorial, links, sites for learning transmission stuff
Old Feb 24, 2012 | 05:10 AM
MadCoder's Avatar
Icon2 Good tutorial, links, sites for learning transmission stuff
I'm a noob and trying to learn about the internals of the transmission.
I have a JDM b18c w/lsd and need to change out the clutch before the swap and wanted to know what I'm buying and why so I can graduate to less of a noob.
Any good sites or links that explains what a clutch, flywheel, how many lbs a clutch should be, the differences, etc?
Thanks,
Jon
Old Feb 26, 2012 | 02:31 PM
Records's Avatar
Default Re: Good tutorial, links, sites for learning transmission stuff
Thanks,
Jon
You'd help me too!
Old Feb 26, 2012 | 04:56 PM
94EG8's Avatar
Seagull Management
Buy the closest you can get to an OEM clutch while still being able to hold the power you're making with a little margin for safety. a 6 puck clutch on a stock daily driver does absolutely nothing for you besides give you a sore leg if you drive in traffic, It's also going to be hard on diffs and final drives and it's not going to last well compared to a full face organic unit.
As far as flywheels go, a lighter flywheel lets the engine rev up quicker, on the other hand it's easier to stall and the RPMs drop quicker as well. Most people will agree that a heavy OEM flywheel works better for boost though. Lightweight is more suited to NA.
renyay
Honda CR-V & Element
Aug 4, 2017 08:54 PM
maniach4x
Jan 30, 2006 09:52 AM
Bowers
Sep 2, 2004 09:52 AM
94ls
Mar 12, 2003 06:07 AM
MHhonda99
Jan 6, 2002 09:18 PM
