KY ***ALL MOTOR EM1*** 2000 civic Si EBP
Contact Info:
Brandon
Flatwoods KY 41139
text only 6O6-585-44I3
Quick Info:
2000 Honda civic Si - $7,500
Item Description:
Okay, I just finished up my project and I still want a red Si. EBP isn't doing it for me... It has a clean title and is in fantastic shape. Body and paint is great. Engine bay and interior are amazing. This car is legit. Not a raped pos. Im the third owner of it. This car has had a ton of money and time put in it. This is the nicest car I've owned to date. Now on to the mod list...
*Bottom End
*B18C1 block, bored .20 over, decked, cleaned, etc
*CP 81.5mm 12.5:1 c/r pistons
*Eagle Rods
*Micropolished GSR crank
*All brand new honda main and rod bearings
*New water pump
*New oil pump
*New timing belt
*New headgasket
*All gaskets and seals were replaced at time of rebuild
*ARP main studs
*ARP rod bolts
*ARP headstuds
*COMPLETELY BALANCED! (Done by John Davis Fabrication)
* Brand new TPR breather can on crank case
*Brand New 2.5inch exhaust with flex pipe
****Has approx 4,000 miles on everything****
HEAD
*B16A head
*Portflow head
*3 angle valve job
*Ported and polished
*Milled
*Cleaned
*Skunk2 PRO1+ camshafts
*Supertech dual valvesprings
*Supertech bronze valve guides
*Skunk2 PRO series titanium retainers
*AEM cam gears
*Gates racing timing belt
*Ferrea valves
*AEBS intake manifold (portmatched to TB)
*blox 66mm throttle body
*P2R intake manifold gasket
*P2R TB gasket
*new BDL bronze fuel rail
*newAccell 310cc injectors
*new injen 3" short ram
*new Hytech tri-y header
*New Accell coil
*new Samco radiator hoses
*new NGK spark plug wires
*New NGK bkr7e spark plugs
TRANS
*B16A2 Hydraulic trans, matching vin
*0 mile stage 2 competition racing clutch and pressure plate
*0 mile Exedy lightweight flywheel
*new axles 0 miles on them
*Skunk2 short shifter with S3 MAG still hood shift ****
SUSPENSION/ MISC
Progress coilovers
skunk2 upper control arms
Hasport billet engine mounts
Full size Mishimoto aluminum radiator
Brand new rotors and pads all the way around
16" Kosei K1 wheels with new cooper tires
wire tuck
rad overflow tuck
new battery
Interior:
Black carpet
black floor mats with red stitching
passwordJDM shift boot with red stitching
black 06 rsx seats
legit mugen pedals
momo 320mm steering wheel with momo adapter
new Alpine headunit cde-121
ENGINE MANAGEMENT
*Hondata S300 installed in a P28
*Dyno Tuned by Dave Blundell aka (Blundar) on a very moderate tune 180hp 158tq. I expect it to make 240whp on race gas.
***This is an old picture with the STOCK SI wheels on it.**** I will get new pictures as soon as I can. Im asking $7500 for it.
Brandon
Flatwoods KY 41139
Quick Info:
Item Description:
*Bottom End
*Eagle Rods
*New water pump
*New oil pump
*New timing belt
*New headgasket
*ARP main studs
*ARP rod bolts
*ARP headstuds
HEAD
*B16A head
*Portflow head
*3 angle valve job
*Milled
*Cleaned
*AEM cam gears
*Ferrea valves
*P2R TB gasket
*New Accell coil
TRANS
SUSPENSION/ MISC
Progress coilovers
wire tuck
rad overflow tuck
new battery
Interior:
Black carpet
black 06 rsx seats
legit mugen pedals
ENGINE MANAGEMENT
