converting no power window to power
Old Feb 23, 2012 | 03:58 PM
soLaLive's Avatar
Default converting no power window to power
i was wondering if converting no power window to power window ..will it be a hard task.. any problems i should know about.. havent dont anything like this.. .. can you guys give me some feed backs..thanks..
Old Feb 24, 2012 | 12:08 PM
turbohatch96y7's Avatar
Default Re: converting no power window to power
I've ddone this to my hatch a few years back. Nothing hard about it there's a good diagram and write up somewhere in the 1996-00 civic section.
Its easy depending on what year car you have and what doors you find.
Basicly I supplied positive and negatives to both doors.
Run some fuses inline and that's it.
The right way is to use the floor harness with the doors you pick up but if you have a 96 and pick up 00 doors it gets tricky with the floor harness but that's why I kept it simple and ran my own wiring.
They still work a good 5 years later.
Old Feb 24, 2012 | 05:06 PM
soLaLive's Avatar
i have a 2000 hatch and i was wondering if i just get two ex coupe doors with power window and then just do the wiring from there.. is that a bad idea??
Old Feb 24, 2012 | 05:17 PM
Yeah that'll work.. the hard part is getting the door locks to work I can't remember exactly what you need to do . Try and find the write up on how to do it there's a thread on it.
Old Feb 24, 2012 | 05:49 PM
soLaLive's Avatar
ive look and cant find it.. i guess i'll just look it up else where.. or unless someone come in and give the thread for it..lol..thanks
Old Feb 26, 2012 | 10:48 AM
fcm's Avatar
fcm
Old Fart
You could also just get a power window kit and install it on your stock doors and windows, Spall makes a pretty good one, it's the one we use.
You get the kit and pick the switches and switch holders that cover the manual crank shaft and your good to go, not as stock looking as switching doors but probably a lot cheaper. 94
Germizzooo
Nov 20, 2011 08:10 AM
b16_madman
Apr 11, 2004 06:16 PM
95excoupe
Mar 9, 2003 12:04 AM
