FITV delete on d16z6
Old Feb 23, 2012 | 12:26 PM
TearSDMF89dx's Avatar
Default FITV delete on d16z6
i've had numerous problems with my FITV ...i know big shocker right?...and also my tps is for lack of a better word f*cked ...i see that blackworks has a throttle body with a tps for $150 but it has no provisions for FITV ...is it gonna be a big deal if i delete it other than the cold start issue and will the iac valve be able to compensate........
and yes ive searched for an hour before i decided to post this
Old Feb 24, 2012 | 12:05 AM
datsol94's Avatar
Default Re: FITV delete on d16z6
As long as its sealed up good you should be fine. Blocked mine off cuz of idle surging almost a year ago, no problems.
Old Feb 24, 2012 | 12:36 AM
Stunna MIKE's Avatar
Mine was blocked with a piece of tape when I got it.. idle'd good, I removed the piece of tape like wtf is this.. and my idle went to ****, ended up taking the FITV off and closed the plastic screw and everything was copasthetic(sp?) again..
long story short yes you can delete/block/bypass it
Old Feb 24, 2012 | 03:25 AM
cool looks like im ordering a new throttle body and a different map sensor
hondahdz96
Engine Management and Tuning
Aug 2, 2015 11:06 AM
Jonathan_ED3
Jan 13, 2009 03:15 PM
dro93si
Jan 5, 2007 08:26 PM
99CivicSiBrian
Jan 8, 2006 09:29 AM
