94-95 power antenna
Old Feb 23, 2012 | 06:12 AM
stnwag0n's Avatar
Default 94-95 power antenna
Does anyone know if the power antenna assembly fits the same between the sedan, coupe and wagon? i know there are some trim pieces for the wagon to make it seal right, but is the actual motor assembly and shaft the same? the wagon antenna motor has a different part number from coupe and sedan, but in the honda parts diagram, it appears the same. Even the bracket that holds the antenna in place is the same part number from the sedan and the wagon. I just want to know if i can to a junkyard and pull one from a coupe or sedan for $50 instead of shelling out $200 at the dealer. Not too many wagons at my local yards.
Old Feb 23, 2012 | 04:05 PM
chikin pickle's Avatar
Default Re: 94-95 power antenna
The power antenna assembly is the same on all hondas that used power antennas from that generation. I replaced my 94 sedan mast with one out of a 92 coupe.
Old Feb 24, 2012 | 01:37 AM
stnwag0n's Avatar
good to know. thanks.
Old Feb 29, 2012 | 02:36 PM
bob441's Avatar
Yes the is good to Know
Old Mar 2, 2012 | 03:21 PM
Lost Again's Avatar
So you are saying the "mast" is the same from a 4th to a 5th gen, YES.
The motor between a 4th and 5th ? I don't think so. (92 EX 4 dr = 39155-SM4-A04 a 94 EX 4 dr = 39150-SM4-A03)
Also a 94 Wagon is different that 94 4 dr (94 5 dr = 39150-SV5-A01 again the 94 EX 4 dr = 39150-SM4-A03).
So the the OP-are you needing the whole motor or just the mast?
stnwag0n
Feb 23, 2012 04:45 PM
Dogginator
Honda Civic (2006 - 2015)
Nov 22, 2011 05:21 AM
stnwag0n
Oct 23, 2003 12:53 AM
MOD5CSi
Acura TL, RL & ZDX
May 27, 2001 10:46 PM
