Camber kit suggestions
Hello everyone. Recently got an alignment and was told they couldn't fully correct the rear camber, and that i need a rear camber kit. Looking for suggestions on a camber kit?? Currently have koni yellows and tein s-techs. Any help would be greatly appreciated. Thanks!!
They can't adjust it at all, so I'm not sure how they would "fully correct" it at all.
If it's less than 2.5* you really don't need to worry about it. Any alignment tech that tells you you need a camber kit or you'll get increased tire wear doesn't understand honda suspension.
Is your car at a reasonable ride height? If your car is "dumped" then solve that issue first.
If the car is at a reasonable ride height, and if you feel that the rear camber is more than you are happy with, then do the washer trick; it's easy and cheap. However, if the rear camber is within reason then I'd suggest leaving it as is. A little camber isn't going to hurt anything. Toe kills tires, not camber (to a certain point).
crazyguy
Jan 3, 2008 12:33 PM
ykwak
Jul 28, 2006 08:54 AM
