EM1 OEM Foglights randomly don't have power anymore, wtf.
Old Feb 22, 2012 | 08:10 PM
Nocturne's Avatar
Default EM1 OEM Foglights randomly don't have power anymore, wtf.
So today I got my Nokya Yellow foglight bulbs. Changed them, didn't do anything to wiring, and now my foglights don't work. The light on the switch doesn't even light up. The ground is fine too.
They worked, just changed the bulbs, and now nothing at all from them.
What should I check? I checked under the dash and everything was plugged in fine. Like I said, I didn't do anything to the wiring so I'm stumped. Only thing I can think of is a fuse but I don't know where it is.
Old Feb 23, 2012 | 04:18 AM
grumblemarc's Avatar
The Grumpiest
Default Re: EM1 OEM Foglights randomly don't have power anymore, wtf.
What happens if you put the old bulbs in?
Old Feb 23, 2012 | 07:32 AM
Cap'N Chronic's Avatar
On my 96-98 Depo foglights there is an inline fuse right after where you hook the power cable to the battery. Try putting the old bulbs back in, and if that doesn't work start testing for voltage, starting at the power cable coming off the battery and work your way around. Make sure you check the relay also.
Old Feb 23, 2012 | 07:39 AM
blankskates15's Avatar
Are you sure they are oem? To my knowledge I thought they were a sealed beam style, therefore you cant change the bulbs? So wiring might be different if they are aftermarket.
Solidis
Dec 12, 2013 08:08 PM
EF9_RIDER37
Jun 23, 2011 01:38 PM
jk7701
Jun 7, 2010 05:10 PM
eh9deux
Apr 19, 2010 02:30 PM
DIYMIKE
Oct 10, 2007 10:54 PM
