93 EG Built K24/K20 Beast *S2K Cluster*Recaro*5 Lug*DSS*Spoon* 263WHP/200Tq 8500$
******8500$ OBO****** ONLY Trade for S2K Have Cash In Hand
Please Bump If You View
It's time to get rid of my hatch. Ive only owned the car for 2 1/2 years now and I just don't drive it enough to keep it any longer. Ive only put 5000 miles on it since I took ownership . Makes me sad seeing it sit. There's a ton of money in this build but unfortunately I wasn't the one to do MOST of the work so I do not have many receipts for the motor build/paint work but the car is put together very well and i have never had any issues. There's definitely things I forgot to list, But that's just an added bonus for the buyer.
Car was Not Cleaned prior to Pictures. Pictures don't do this car justice.
Located In PA- 40 mins from Harrisburg
PM or Call/Text 717-475-2410
E-mail Jrey035@yahoo.com
1993 CX HatchBack No Rust and Minor Scratches and a Small Ding. Interior Is pretty clean also.
Interior
-JDM Red Recaros
-S2k Cluster with extremely nice mold job looks like it should be there! Everything works minus the Engine Temp.
-NRG quick release
NRG HUB
MOMO Steering wheel
-AEM gauges (Engine Temp and AEM wideband gauge) Wideband sensor is burnt out as of this moment but have an LC1 to install that will come with the car if i dont get around to putting it in before it sells...
Exterior
-16'' 5 lug Rota J-mags in really good shape no curbs or anything. Nitto Geon Tires
-Jdm Amber Corners
-Jdm Fogs
-Jdm Headlights with carbon eyelids
-Carbon fiber DuckBill
-Carbon fiber Trunk
-Fake Carbon wrapped hood. (Part of the underneath is cut out because i guess the hood wouldn't close for the last owner) Hood can now close with plenty of clearance
Suspension
-K-sport fully adjustable one piece coilovers
-JDM ITR Full 5 lug conversion...
-Legit Spoon front and rear upper sway bars
-silver rear LCA's
MOTOR
-K24a4 block vin number-1hgcm72554a025951 Out of 04 Accord
(https://www.nicb.org)---Check the vin motor is legit
-12.5-1 CP pistons
-Blue Print Rods
-ACL Race Bearings
-Micro Polished Crank
-Balanced Crank
-OEM Oil Pump
-OEM Water Pump
-All new seals and gaskets
Head
-2004 RSX Type S Head
-RBC Intake Manifold
-RC 750 Injectors
-Ferrera Valves
-Ferrera Guides
-Ferrera Seals
-Skunk 2 Stage 2 Cams
-Skunk 2 Springs
-Skunk 2 Retainers
-SSR Header
-3inch thermal stainless steal exhaust
Transmission
-05 RSX Type S 6 speed Tranny. The trans was Just rebuilt 2/11/2011 at Innovative Motor Works by Shawn Quickle.
New 1st and second with main shaft.
1-3 Syncrotech Carbon Syncros.
New M-Facotry LSD
Running Pennziol Syncromesh Tranny Fluid Has at most 1k on Tranny Work and drives like
-DSS 3.9 axles (installed on the passanger side, still a stock rsx on drivers side but other DSS axle will come with sale...)
-Comp Stage 3 Clutch
The car was tuned on KPRO at IMW by John Kerr a few months after i bought it. Put down 263whp/200ftlbs on 93 I have the Dyno Graph and all receipts. Just replaced the battery odyssey battery. Always ran Mobil 1 Full Synthetic Every 1500 Miles Since Ive owned it. Just replaced the starter and alternator.
Interior
-JDM Red Recaros
-NRG quick release
NRG HUB
MOMO Steering wheel
Exterior
-Jdm Amber Corners
-Jdm Fogs
-Carbon fiber Trunk
Suspension
-silver rear LCA's
MOTOR
-12.5-1 CP pistons
-Blue Print Rods
-ACL Race Bearings
-Balanced Crank
-OEM Oil Pump
-OEM Water Pump
Head
-RC 750 Injectors
-Ferrera Valves
-Ferrera Guides
-Ferrera Seals
-Skunk 2 Springs
-Skunk 2 Retainers
-SSR Header
Transmission
New M-Facotry LSD
Innovative Motor Works did the cluster. Lots of interest. Let's find this car a good home.
tdubbebawllin
28
Jul 29, 2009 08:45 AM
FT: 93 cx built gsr,D2's, buddyclub.. much more AND !!!!! 01 Lexus IS300 Indash DVD, Tint and more..
mugencivic94
Sep 17, 2007 03:29 AM
