heat problem on my car
Old Feb 22, 2012 | 03:07 PM
2low93's Avatar
Default heat problem on my car
i have been having heat problems..there is no air coming out of the vent the blower aint coming on. I have checked the fuse and the relay those are good. took the the blower motor out and hooked it up to a battery and it works. took the blower motor resistor out it is good. today i took out the heater control panel and check the the blower motor switch thats good but when i check the connector for the blower motor switch i wasnt getting any volts out of it now since there no voice the relay is wat power the switch could that be out if u know anything bout this lmk what i can do to fix.btw it on a 93 honda civic ex
Old Feb 22, 2012 | 03:25 PM
WallaceB18's Avatar
Default Re: heat problem on my car
Possibly the contacts on the control panel have corroded, if the blower is good then I would get the circuit is open somewhere.
Old Feb 22, 2012 | 03:42 PM
2low93's Avatar
whats they best way to do that...everthing is good but if the the blue and white wire is not getting current then its maybe the relay
Old Feb 22, 2012 | 05:35 PM
hybridmiklo's Avatar
the blower resistor
Old Feb 22, 2012 | 08:03 PM
2low93's Avatar
thats good the spring is still good but i will check the current tomorrow what if the spring is good could it still be bad????
jjbird92
Honda Civic (2001 - 2005)
Aug 30, 2014 09:46 AM
pityocamptes
Aug 9, 2014 09:03 PM
civicej897
12
Apr 4, 2013 08:23 PM
toolow69
12
Nov 3, 2008 09:39 PM
autoxthis
Jul 10, 2008 01:41 PM
