b16a2 custom supercharger kit with fmic
Old Feb 22, 2012 | 12:10 PM
jima3morris's Avatar
Default b16a2 custom supercharger kit with fmic
just thought id post pics of a project that ive nearly finished ,
i have a b16a2 in a classic mini and im in the process of building a supercharger kit , would like to know peoples opinions on it , my thinking was everyone seems to complain about the heat associated the jackson sc , so ive built a kit that allows a intercooler or charge cooler to be used, space is limited in the mini so i have decided to run a fmic to start with , here are some pics, i would like to hear peoples feedback , jim
Old Feb 22, 2012 | 12:14 PM
Default Re: b16a2 custom supercharger kit with fmic
heres the car
Old Feb 22, 2012 | 01:10 PM
DirtyDA9's Avatar
Dude that is so fuggin awesome! And totally badass. Very interested to see how this works out.
MRGRIM's Avatar
R.I.P. Mark
sweet ride
would like to see more on that pulley setup
Old Feb 22, 2012 | 01:13 PM
Purple_GSR's Avatar
Originally Posted by MRGRIM
sweet ride
X2
Old Feb 22, 2012 | 01:22 PM
crvtectim's Avatar
Want!
Old Feb 22, 2012 | 01:24 PM
th3pwn3r's Avatar
Pretty awesome, I've never seen anything like this.
Old Feb 22, 2012 | 03:43 PM
Smokinsax's Avatar
The Boot
very interested in this setup...
looking forward to some updates.
Old Feb 22, 2012 | 06:51 PM
skateboard_ej8's Avatar
im hench irl
Whoa that's really different.. Post more.
Old Feb 23, 2012 | 02:12 AM
rich7777's Avatar
Very intresting
Old Feb 23, 2012 | 12:05 PM
The charger runs of the back of a double sided poly v belt , the engine drives anti clockwise and the charger drives clockwise, everyone makes it out to be a problem that the charger runs opposite , but its really not hard , cheers for comments , jim
Old Feb 23, 2012 | 12:13 PM
kyden's Avatar
i love it. although it is not a problem in your case, but your pulley setup would not fit in a honda chassis.
Old Feb 23, 2012 | 07:56 PM
ZMX's Avatar
ZMX
Wow. Awesome.
I want to see what this thing turns out like.
Old Feb 23, 2012 | 09:08 PM
charger running but without boost pipes and intercooler connected, it lives !!!!!
[IMG][/IMG]
Old Feb 24, 2012 | 02:15 AM
Natural Aspirations's Avatar
You can change the rotation of the M62 by flipping the rotors (driving the other side).
Nice fabrication but changing the rotation would have saved a lot of work. Mounting the charger where the alternator is also would have been a option then.
Old Feb 24, 2012 | 03:42 AM
The pics make it look like there's space by alternator, some of the body work has had to be relieved just for alternator , there is no way the sc would fit there , I truest everywhere , loads of possibilitys but not without cutting into wings front panel if bonnet, and that wasn't Wat i wanted to do , regarding switching rotors, I wanted it to be so if anything went wrong with charger just swap it , cheers Jim
Old Feb 24, 2012 | 04:34 AM
Understood, good to see you looked at all options.
Old Feb 24, 2012 | 07:59 AM
Jeffaj20's Avatar
WOW! What in interesting setup, Kudos to you!
Old Feb 24, 2012 | 01:28 PM
Smokinsax's Avatar
The Boot
Please explain your distributor setup...
Old Feb 24, 2012 | 02:13 PM
Any thoughts on how your going to handle recirculation? AKA bypas valve
Old Feb 25, 2012 | 05:05 AM
Car runs on dta stand alone ecu, so no distributer, there's a trigger wheel on crank pulley, then a ford coil pack , ,
I have a vacuum operated recirculated valve so whenever throttle is closed the supercharger boost will recirculate. Cheers
Old Mar 1, 2012 | 10:32 AM
raider16v's Avatar
Looks fantastic Jim,
Hope you get it all sorted for Mini in the park? so we can have a little heads up and see whats what.
All the very best!!
Amazing work keeep it up.
Take it easy
Mark.
B16a turbo classic Mini.
Old Mar 5, 2012 | 04:03 AM
Sounds good to me. I've got the map booked for end of month. So as long as it doesn't go bank then yer ill be there , I think were pretty local to each other, you should pop over ir sonething, Jim 07816053563 if you wanna give me a shout
Old Jul 18, 2012 | 04:36 AM
For any one who's interested, there are some videos of the car in action on.youtube , just type in mini.vtec supercharged , there should be 3 videos from in car ,Jim. Car is running 260bhp and 190 torque
Old Jul 18, 2012 | 05:13 AM
usdm ej1's Avatar
Very awsome nice set up
