Function 7 LCA with Endlinks how to isntall???
Old Feb 22, 2012 | 10:23 AM
SpoonREVS's Avatar
Default Function 7 LCA with Endlinks how to isntall???
So I decided to replace the suspension on my ITR… and now I’m having some issues installing the End links. Please keep your negative comments to your self No need for them or have the time to read them.
I bought a set of Function 7 LCA's with there Function 7 Heim Sway Bar End Links
now here is the deal I cant figure out how to install the sway bar end links. They did not come with any kind of instructions I check online and I found a lot of old threads asking the same question but not actual instructions on how to install them. Does any one have any ideas how to install them and can show me pictures.
this is what I have so far.. but the bottom bolt is to long and it has play.. or is it suppose to be like this?? Or how Im suppose to set them up?
Old Feb 22, 2012 | 01:27 PM
d=f20c1's Avatar
Default Re: Function 7 LCA with Endlinks how to isntall???
Looks like you have them backwards Just going by the pic
http://www.jhpusa.com/store/pc/viewP...idproduct=1963
Old Feb 22, 2012 | 01:47 PM
SpoonREVS's Avatar
I dont know... any could just put them like that to throw a picture of it.. and maybe is not the correct way.
Old Feb 22, 2012 | 04:04 PM
d=f20c1's Avatar
Well wouldnt hurt to try
Old Feb 22, 2012 | 06:49 PM
BlueIntegraBoy's Avatar
Does the bottom bolt feed through the endlink first and then you nut it off on the LCA side?
Old Feb 22, 2012 | 07:20 PM
doood's Avatar
been there done that
have you tried contacting function7 directly? when i was having problems with my lcas they were pretty good about returning emails.
Old Feb 23, 2012 | 06:33 AM
SpoonREVS's Avatar
yeah im give it a shot and see what happens
yeah... but thre like a gap where the bottem bolts has room to slide Im not sure if its suppoer to be like that because any other way you install it the nut would not hit the lca because the bolt is to long
Yeah call several time but no answear so i email them hopefully i should get a reply soon.
Old Mar 15, 2012 | 03:15 PM
hon-daddy's Avatar
easy fix. return the f7 end links and get asr. they come with the spacers you need.
granny racer
Dec 22, 2022 07:07 PM
bennyboie
Jun 15, 2009 07:43 AM
LukieLuc
Jun 30, 2007 08:17 PM
JMelt4
May 4, 2007 03:16 PM
CRX7
Oct 11, 2002 04:59 PM
