Transmission & Drivetrain Gearboxes, Differentials, Clutches
S20 vs. S40
Old Feb 21, 2012 | 07:26 PM
Mr.F's Avatar
Default S20 vs. S40
I currently have an S20 that has a few slight issues. I picked up a lower milage S40 but was told I will hate the gear ratios. Any thoughts?
Old Feb 21, 2012 | 07:31 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: S20 vs. S40
depends which S40 you bought as compered the the S20 you have now.
Old Feb 22, 2012 | 05:28 AM
svtford4x4's Avatar
b000 is the shorter gear ratio, big bearing trans, from ex/si. I read somewhere there might be one exception in the form of hx, which has longer gear ratio. The gear ratio can be changed with aftermarket gears from mfactory or similar company.
Old Feb 23, 2012 | 07:28 AM
Mr.F's Avatar
It is the one from a Hx. I thought it was from a Si when I got it until I ran the numbers on the side.
Old Feb 23, 2012 | 10:52 PM
Mista Bone's Avatar
D Tranny Guru
Which the numbers were?
Also you from Canada?
Old Feb 24, 2012 | 03:57 AM
94EG8's Avatar
Seagull Management
Semi related note: The HX was never sold in Canada. I've seen exactly one of them here and it was in a junkyard and missing the drivetrain and wheels.
Old Feb 24, 2012 | 07:41 PM
SpeeD MoNsTa's Avatar
is there any other way to know if i have a a000 or b000? i have a stock 95 eg but it didnt bring its stock tranny, the guy who sold it to me just mentioned it had a "desireable" transmission. at that time my knowledge was pretty low and didnt payed mind, now when i check the tranny for the codes it says S20 2433578 and cf5 p20 but it doesnt say a000 or b000 anywhere, last thing i hoped for was to record a video of me shifting to see if anyone with expirience can tell me if they sense the ratios and can tell me there opinion of wether it might be a b000 or the stock a000?? ive just been lost with this.
Old Feb 24, 2012 | 07:58 PM
94EG8's Avatar
Seagull Management
It's stamped in the case just above the fill hole.
Old Feb 24, 2012 | 09:17 PM
thanks! ill check it out.
Old Feb 24, 2012 | 10:31 PM
Mista Bone's Avatar
D Tranny Guru
C5F is a P20/A000 case, not desirable gearing. I wanna say it is a DX/LX tranny,
C5E would be CX/VX.....I'd have to check.
Old Feb 24, 2012 | 10:32 PM
Mista Bone's Avatar
D Tranny Guru
cast, not stamped
Old Feb 25, 2012 | 11:51 AM
Im really lost here, i google the code last night and was able to see what to look for and what it looks like, but just went to check and couldnt see anything anywhere, im a noob and this is my first car. is the code anywhere around here or do i need to get underneath? i took a pic but i guess i cant upload it directly from my computer.
Old Mar 5, 2012 | 02:49 PM
Mr.F's Avatar
My tranny has a bar code that says E7F then below P4A.
Old Mar 5, 2012 | 11:53 PM
Mista Bone's Avatar
D Tranny Guru
bar code means nothing....
imzjustplayin
Apr 12, 2008 12:28 PM
Biggmike92vx
Sep 29, 2007 10:43 PM
foxbody5l
Aug 17, 2005 10:21 AM
RangerDan
Jan 26, 2003 11:42 AM
