Fs diss assembled built gsr
1997 gsr. JH4DB8583VS000089
Still in plastic from machine shop. Needs to be assembled I have everything to assemble except bearings and head gasket timing belt a water pump.
Eagle h beam rods
Cp 9.0-1 piston heads 81.5 mm
Cleaned and polished crank.
Arp head studs
Head
Stock valves and cams
Blox dual valve springs
Blox titanium retainers
Skunk 2 valve seals
Head was assembled by the machine shop
Skunk 2 pro 1 intake manifold
Golden eagle fuel rail
Golden eagle oil squiter plugs
Golden eagle intake manifold gasket
Distributor
moroso oil pan
I'm sure I'm forgetting stuff... I don't need to sell wont respond to low ball offers.
Will not piece out!! All offer for just pats will be ignored
Asking $1600 firm will trade for crx si
Call or txt 8458495122 absolutely no call after 9pm will not call or respond.
Eagle h beam rods
Arp head studs
Head
Skunk 2 valve seals
Distributor
moroso oil pan
TurboR1391
Sep 8, 2006 07:08 AM
