d16y8 into ef std hatch... questions
Old Feb 21, 2012 | 05:20 PM
t-town_ep's Avatar
Default d16y8 into ef std hatch... questions
So I've been doing lots of research, but I seem to be confused here. I plan on buying a d16y8 and putting it into my ef with the 4spd tranny. (just a daily so i dont care, found a cheap y8)
So i have to convert the y8 to obd1, then convert the car from dpfi to mpfi, and from obd0 to obd1 correct?
If I were to get this jumper harness, what else would i have to convert?
http://www.boomslang.us/obd0to1.htm
help me out here HT
Lee
Old Feb 21, 2012 | 05:23 PM
88LsRex's Avatar
Default Re: d16y8 into ef std hatch... questions
Just get a OBD1 jumper.
Run: D16z6 Distributor
P28 Ecu
Old Feb 21, 2012 | 05:42 PM
t-town_ep's Avatar
obd1 jumper? like the jumper harnes for the ecu?
Old Feb 21, 2012 | 05:43 PM
91efbluehatch's Avatar
dont get p28, run the right ecu
get a obd0 to obd2a conversion harness and run a obd2a P2P ecu
Old Feb 21, 2012 | 05:45 PM
crx_si-r's Avatar
P28 Ecu
Z6 distributor will not bolt up. If you can get the y8 distributor (96-98 model) then your set. You will also need to get an obd2 iat sensor because the y8 manifold does not have a spot for it. The y8 had the iat sensor located on the intake hose.
In order for that ecu jumper to work you will need to fully convert your car to mpfi.
Or you can get one of these:
http://www.youtube.com/watch?v=puPiw...e_gdata_player
Full plug n play conversion
Old Feb 21, 2012 | 05:47 PM
crvtectim's Avatar
Yes, you have to do the dpfi to mpfi conversion first. Then jumper harness for ecu and distributor. Use your engine harness, not the y8's if it even comes with one. Run the appropriate wires from the ecu jumper harness to vtec sol., pressure switch, ks, and O2.
Old Feb 21, 2012 | 05:50 PM
t-town_ep's Avatar
sounds like i need to do more research, still completely lost.... LOL
use my engine harness? so everything on my harness (d15b1) will connect to everything on the y8? then all i have to do is use the obd0 to obd2a jumper harness to run the p2p ecu?
Old Feb 21, 2012 | 05:57 PM
look. your b1 needs to be converted from DPFI to MPFI. i can guide you through it if you want as i just got through converting mine. the p2p ecu will run the y8. the p28 is for the sohc z6.
you cannot simply "plug" yourharness into the b series motor. some sensors wont work and such. PM me any questions you have and i will be glad to lend personal pics of my build
Old Feb 21, 2012 | 06:04 PM
t-town_ep's Avatar
i understand the dpfi to mpfi part, but im not sure on what harness to use.
and its not a b series motor. its a d16y8
Old Feb 21, 2012 | 06:08 PM
crx_si-r's Avatar
Ummmmm......
The y8 is a sohc vtec motor. Same as the z6. If you do the obd2a conversion the you will also need to add in the crank position sensor located at the oil pump. As well as add in a knock sensor. Get an obd2 cat with a secondary o2 sensor.
It is easiest and less confusing to run a p28. Which is essentially the predessesor to the y8.
Old Feb 21, 2012 | 06:11 PM
crx_si-r's Avatar
OP, here is what you will need to do in a nutshell:
1. Take your stock dx harness and convert it to mpfi
2. Add in the necessary obd1 conversion components:
- distributor (I recommend the obd2a y8 distributor as the z6 will not bolt up)
- 4 wire o2 sensor
- p28 ecu
- obd0 to obd1 ecu jumper
- run vtec wiring
3. Locate a y8 intake pipe (or cut a hole to run the iat)
Old Feb 21, 2012 | 06:19 PM
t-town_ep's Avatar
sounds great, that makes it all the much easier for me.
anything else that im missing?
will almost everything from my b1 harness plug up to the y8 motor?
Old Feb 21, 2012 | 06:30 PM
crx_si-r's Avatar
Yes. You will need to re wire your fan switch from the back of the motor to the thermostat housing
Old Feb 21, 2012 | 07:30 PM
t-town_ep's Avatar
so i would still need to get obd1 injectors/alternator and all that?
Old Feb 21, 2012 | 07:38 PM
crx_si-r's Avatar
no. your alternator will work fine (obd0 and obd1 are the same, only obd2 has a different connector).
as for injectors:
88-91 Civic/CRX (Si, HF and EX models) & 90-91 B18A1 if your injectors come form these cars then you will need a resistor box
92-00 Civic & 92-01 Integra, if your injectors came from any of these cars then you will not need a resistor box.
accord and prelude injectors will also require a resistor box
Old Feb 21, 2012 | 08:57 PM
KINGVEM^^ED6's Avatar
Isnt ef alternstor 3rib and y8 crank pulley is 4 rib iirc
Old Feb 21, 2012 | 10:00 PM
t-town_ep's Avatar
yea the b1 crank pulley is 3 rib, but i will probably end up using the b1 crank pulley. i dont need power steering.
Old Feb 22, 2012 | 06:36 AM
I was always told not to switch crank pulleys
Obd1 alternator.92-95 civics have the same.plug but arE 4 RIB
Also your.gonna.reuse the b1 mounts
I shaved the timing cover.a lil to make it clear the mount
Old Feb 22, 2012 | 09:49 AM
DCRB's Avatar
OK o/p first off google dpfi to mpfi conversion. EASY to do, i've done it multiple times on friends cars.
then do this:
- 4 wire o2 sensor
- p28 ecu
- run vtec wiring
and do this too:
Also while you have the y8 out of the car take the time to replace water pump/timing belt on it so you don't have problems later down the road.
hopefully your y8 does come with an engine harness, so you can salvage it for the following:
Injector clips
Vtec wires
4 wire o2 sensor
fan switch
iat wires
distributor plug
as well as any plugs that will be brittle and have broken wires (like the 2 plugs under the distributor from it leaking)
As far as clutch and fly wheel is concerned, re use or purchase new a clutch and fly wheel for your transmissions year. not the motor
on your y8 intake manifold, make sure it isn't out of an automatic, the Idle air control valve is different, and uses 3 wires vs the manual 2 wire one, also the auto iacv is located on the throttle body not the back of the intake manifold as seen below
last thing, its "ghetto" but i have gotten away with un screwing the stock IAT, poking a hole into my intake coupler and tip tieing the obd0/1 to the coupler
Old Feb 22, 2012 | 10:08 AM
t-town_ep's Avatar
the y8 is an automatic... can i just simply switch from an auto-manual intake manifold? im sure i can find one for cheap.
Old Feb 22, 2012 | 10:16 AM
crx_si-r's Avatar
Yea you can use the manual manifold
Old Feb 22, 2012 | 10:30 AM
t-town_ep's Avatar
awesome! thanks to everybody for their help! Im sure I will have more questions here in a few days.
Old Feb 22, 2012 | 10:41 AM
Bently_Coop's Avatar
Steve at Heart
Whats the solenoid on the back left of the z6 manifold for and is it neccessary?
Old Feb 22, 2012 | 10:42 AM
Ask away when ready
Old Feb 22, 2012 | 10:59 AM
t-town_ep's Avatar
if there is anything else that im missing, or that i should know, please feel free to add.
thank you.
