chipped P28, GSR, turbo stuff, hatch part out.
Old Feb 21, 2012 | 04:20 PM
NotAJDMFanBoy's Avatar
Default chipped P28, GSR, turbo stuff, hatch part out.
I have some extra parts, just looking to get some money to fund an H swap.
P28, can chip it to Hondata S300 or Crome. Been chipping ECUs for people around here for about 3 years now. $150
P72 GSR head, came off a 1996, includes cams, VTEC solenoid and your choice of a bare aluminum, gloss red or metallic copper valve cover. May need a few bolts for the VTEC solenoid. Make offer
P72 GSR block with girdle and caps. Make offer. Prior owner spun a rod bearing, but could be micropolished and I have a set of 4 good pistons and rods. Make offer.
Turbonetics T3/T4 turbo. .63ar hot side with ford 5 bolt pattern and 57 trim cold side, includes a flange with a short pipe for starting making your own down pipe. It has some shaft play and burns a little oil, but I have new bearings (journal and 360 thrust bearing) and seals from Garrett. Selling because Im upgrading. Make offer
DSM 1G BOV, 2 of them, have a 2.5" pipe with flange welded on. $20 for 1 BOV, 35 for both and the pipe?
Precision 880cc peak and hold injectors with plug and play resistor box. Plugs into dead end plug on 92-95 Civic and maybe others. May need wires rearranged, but it eliminates the need to cut and solder your harness. Used 3000 miles and switched to ID1000s. $190?
GM 3 BAR MAP sensor with pig tail and wire leads from car it was installed on. Used 1 week on a D16Y7. $40?
B/H/K series (32mm / 1.25") radiator hose fitting. Place inline with radiator hose and it has a 1/4NPT fitting to put a temperature sensor, turbo coolant feed in or use it as a drain or purge for H series swaps to facilitate purging the air from your system. Make offer.
92-00 D series throwout bearing. Nachi (same as OEM). New, never used, was sent the wrong one and needed B series. $20
I have oem 240cc injectors, OEM GSR intake manifolds, D series alternators, manual and auto D series starters, alternator brackets, a D15B7 intake manifold, miscellaneous sensors, distributor parts
1993 Civic CX hatch part out. Gray interior. What happened was the engine I had in it blew up and I got laid off so I started tearing it apart, then had like 24hrs to get a vehicle so I got another vehicle and just never put this back together. It's missing the front end and seats as well as suspension.
Old Feb 21, 2012 | 07:23 PM
Skunk U's Avatar
Default Re: chipped P28, GSR, turbo stuff, hatch part out.
Pmd
Old Feb 21, 2012 | 08:25 PM
hardcore97's Avatar
by front end do you mean just the hood fenders fenders and bumper?
Old Mar 8, 2012 | 02:29 PM
devastor23's Avatar
so the chipped p28 is chipped with hondata s300
Old Mar 8, 2012 | 02:48 PM
meng22's Avatar
Where are you located? I need the headliner
Rtboy10
May 13, 2010 08:05 AM
BoostedsiR
Mar 11, 2004 06:11 AM
