dohc zc ecu
Old Feb 21, 2012 | 01:23 PM
efstunnin's Avatar
Default dohc zc ecu
ok so im running a pr4 ecu in my ef hatch
its been kinda hesitating with power around 3000 rpms
ive been looking for a pm7 ecu or pm6
so i jus tried a pg7 from an older teggy and she wouldnt even start up
and same thing when i tried a pm5 ecu
i reset the ecu and everything before i started the car so idk why they each didnt start
Old Feb 21, 2012 | 01:28 PM
JDpower's Avatar
Default Re: dohc zc ecu
I currently run a PG7 on my dohc zc and it runs it pretty good so idk why it wouldn't start for you. And I had previously ran a pm6 on it before I got the pm6 and it ran it alright too. Either one of those would run it better than a pr4 which is for a 1.8 L.
Old Feb 21, 2012 | 01:31 PM
bradley's Avatar
PM5 is a DPFI ECU, won't work on any MPFI setup.
PG7 will only work from 88-89 Teggy.
Old Feb 21, 2012 | 01:43 PM
90civic-ZC's Avatar
Yeah man the PM5 wont work but that PG7 should've....was the computer bad? Usually if the computer is fried the LED will just stay lite constantly.
Old Feb 21, 2012 | 01:57 PM
bradley's Avatar
IIRC the 88-89 PG7 doesn't have an LED, and the 86-87 PG7 doesn't either but the casing is different (it has crossed ribs instead of being flat) and it won't work due to not using electronic timing advance.
I'm assuming you got handed a 86-87 PG7, find an 88-89 PG7 or PM7 or chip the PR4 (all PR4's can be chipped, they are almost identical to the 90-91 PM6 inside).
Pics of the PG7 ECU would help ID if it is incorrect or not. Specifically the front case and the label.
Old Feb 21, 2012 | 03:53 PM
efstunnin's Avatar
the pg7 only cranked but never fired
is the firing order the same os the one for the pr4 or would it be different
and it does have the led light its on the side of the case and no it never lit up
i inspected before i put it in and everything looked really good
no burnt parts or anything
Old Feb 21, 2012 | 03:57 PM
efstunnin's Avatar
[IMG]file:///C:/Documents%20and%20Settings/Guest/My%20Documents/Downloads/photo.JPG[/IMG]
efstunnin's Avatar
Old Feb 21, 2012 | 03:58 PM
efstunnin's Avatar
Old Feb 21, 2012 | 04:50 PM
JDpower's Avatar
The PG7 does have an LED but its not in the same spot as a pm6 and you have to use one from an 88-89 integra as they make pg7's for 86-87 teg's that dont work. The LED should blink one time (to say hello when the key is turned) then go out.
Old Feb 21, 2012 | 04:52 PM
efstunnin's Avatar
why wont the 86-87 work on the zc
Old Feb 21, 2012 | 05:12 PM
JDpower's Avatar
Because on an 86-87 integra they came with vacuum advanced distributor and the 88-89 teg's had electronic advanced distributors like our ZC's (unless you have a brown top zc). I assume you have an 88-89 zc which you would need an 88-89 PG7. The 86-87 ecu will have this big X on it that's how you'll know.
Old Feb 21, 2012 | 05:16 PM
efstunnin's Avatar
ya its an 89 zc
the firing order and everything is gonna be the same though right
i might just have to play with the dizzy placement
Old Feb 21, 2012 | 05:20 PM
JDpower's Avatar
Check to see what kind of pg7 you have because if you have the 86-87 ecu it won't matter how much you mess with the dizzy its not gona work. The firing order is the same but one uses electronic advance and the older one relize on vacuum readings which you wouldn't have on your 89.
Old Feb 21, 2012 | 05:23 PM
efstunnin's Avatar
oh alright
im pretty sire i have a 86-87
cause i played with the dizzy today and nothing changed
so ima have to go look for a newer one
Old Feb 21, 2012 | 05:24 PM
90civic-ZC's Avatar
I always wondered how the old brown tops would run on a PM7....(I know we're talking about a PG7 but I'm just refering to the best ecu for the ZC the JDM PM7). It never even dawned on me that they would use a different ecu for the brown top vs the black. O.P. can you not find a PM6?
Old Feb 21, 2012 | 05:29 PM
efstunnin's Avatar
so far i havent found a pm6
someone messaged me saying they have one
but wich one would work better in your guyss eyes.
the pg7 or the pm6
Old Feb 21, 2012 | 05:36 PM
90civic-ZC's Avatar
ultimately the PM7 but as the PG7 was for a DOHC and the PM6 SOHC, I would shoot for the PG7 but the PM6 is usually the easiest to get ahold of. Did you message that guy I sent you a PM about?
Old Feb 21, 2012 | 05:38 PM
efstunnin's Avatar
i couldnt find him
i searched a lil for him but nothin came up
Old Feb 21, 2012 | 05:43 PM
90civic-ZC's Avatar
Damn, well that's the only lead I've got for a PM7....I don't know where you got your PG7....but you could try googling near your area for a import engine place and call them to see if they have a PM7 or PG7, craigslist, ebay........or sadly and expensively enough you can go to Advance Auto and they sell referbished ones for way too much money but they'll have a PM6 and PG7. About four months ago I priced out a PG7 for the hell of it and it was in the $300 range.
Old Feb 21, 2012 | 05:46 PM
efstunnin's Avatar
i know theres a bunh of junkyards by my pad. worst comes to worse i rumage around there and see if i find one and rip it open and see what condition its in.
i found like one or two on craigslist but they are like an hour drive from me and i really dont wanna drive that far but i might have to
Old Feb 21, 2012 | 06:16 PM
bradley's Avatar
Honestly I think his best bet is to chip the PR4 he has, go to Xenocron's website, and get a basemap for a ZC.
The socket is like, $10 I think? And the basemap is less than that IIRC. It's the best way to go, cheap and you'll get EXACTLY what you need. Plus upgrades down the road can be tuned in!
Old Feb 21, 2012 | 06:27 PM
efstunnin's Avatar
how would i go about doing that bro
Old Feb 21, 2012 | 06:30 PM
90civic-ZC's Avatar
For his situation I kind of agree "bradley" since he's having problems seeking out a proper ECU.
Old Feb 21, 2012 | 06:42 PM
efstunnin's Avatar
im on there website but have no clue what to look for or what its called.
any help would be nice lol
never chipped an ecu before
