2005 Accord trunk light doesn't turn on when open
I need some help. I have an '05 Accord and each time I open the trunk the light doesn't turn on. The bulb is fine and I checked all the fuses which I think are connected to the trunk but all fuses are fine.
Today, I accidentally left the trunk open while driving and noticed the trunk indicator light on the dash wasn't on. I wonder if the two are related?
Can anyone help with the fix to this?
Sounds like you have have a damaged wire somewhere.
Have a look at the harness in the trunk and see if you may have a damaged wire or something there.
If the bulb and the fuse is ok, and no other fuses are burnt out then I would guess as it being a wiring issue.
lpdrumer
Feb 20, 2011 04:25 PM
