Trunk Dash light stays on but not light in trunk itself
Old Feb 21, 2012 | 09:59 AM
Andrewzabomb's Avatar
Default Trunk Dash light stays on but not light in trunk itself
yesterday i took my 2000 civic ex through the car wash and the trunk open dash light randomly turned on. the trunk was closed and i stopped to slam it but it still remained on. the light inside the trunk stays off and the trunk stays locked. i tried disconnecting the wires from the back of the latch with and the trunk dash light started flickering on and off. any help?
Old Feb 21, 2012 | 10:42 AM
motegicivic's Avatar
Default Re: Trunk Dash light stays on but not light in trunk itself
Just in case check the dash bulb, could be on it's way out. Sometimes those bulbs act funny when they are ready to go.
Old Feb 21, 2012 | 10:58 AM
do you have to take out the cluster to get to the bulb?
Old Feb 21, 2012 | 11:32 AM
jbpnoman's Avatar
Yes, but it's a fairly simple process. 5 screws and a couple pressure clips.
Old Feb 21, 2012 | 11:39 AM
Wrona's Avatar
there is 6 screws
2 at the top of the bezel that the gauges sit behind they are at the very top
4 that are on the cluster itself 2 up top 2 on the sides ull see them than u just pull otu the cluster
there are like 4 or 5 plugs depending if u have an auto or a manual just press the little clip and pull u should be able to pull out the cluster with the wires hooked up enough to see behind to actually see where the clips are
just fixed it. took off the latch, cleaned things up. i think something got knocked loose.
Old Feb 21, 2012 | 11:49 AM
NVturbo's Avatar
O.G. triple O.G.
Can't believe you guys even suggested to remove the dash bulb even when it was obviously the latch/contactor. C'mon folks...
Old Feb 21, 2012 | 11:56 AM
definitely the last thing i would have thought of doing. thanks anyway though guys
Old Feb 21, 2012 | 12:32 PM
He said he was playing with the latch first and had the same issues.
I know with the dash bulbs the do not completely burn out, but work randomly, like my bulb for the d4 in my dash will work randomly, I never got around to replace it.
andre3wap
Jan 9, 2014 09:14 PM
Riga89
Sep 23, 2007 02:17 PM
rleonekc
Mar 30, 2006 11:14 PM
StockTeg
Nov 21, 2001 02:35 PM
