d16y7 into 1997 civic EX, wont run with d16y7 ECU
look around for a write up or info on doing a 3-pin to 2-pin IACV conversion. Y8 manifold onto a Y7. your EX chassis harness may need to have a wire added and maybe two others swapped. i don't remember more specifics, but hopefully that will aim you in the right direction.
Not cranking or not starting? Do you have spark? Fuel? Does the CEL come on for two seconds and cut off when placing the ignition in accessory?
Ekcoupeblack
Jun 10, 2015 09:54 PM
Dstaks716
Sep 5, 2010 05:50 PM
fernruffryders
17
Apr 8, 2008 04:08 PM
