Throwout Bearing or Input Shaft Bearing?
Old Feb 21, 2012 | 12:30 AM
Unphzd's Avatar
Default Throwout Bearing or Input Shaft Bearing?
At first when you start the car it would make a whining sound and when you press the clutch in all the way it would make a whining noise. I kept driving and it stopped. Now it kinda jerks when i set it to gear and slowly engage into gear. Does the throwout bearing need replacing?
Old Feb 21, 2012 | 06:25 AM
aznEKchick00's Avatar
Default Re: Throwout Bearing or Input Shaft Bearing?
i have the same issue, i got a 2000 honda civic.
we replaced a throwout bearing, and it didnt change the noise
Old Feb 21, 2012 | 07:16 AM
sde780's Avatar
When you leave it in neutral without stepping on the clutch does it make noise? That's usually indicative of the input shaft bearing
civic ef
May 29, 2012 01:02 AM
AddictedToBoost
Feb 25, 2012 07:58 PM
akacoke
Jun 27, 2011 10:48 AM
ether.real
Oct 7, 2009 06:49 PM
pinky5
Nov 12, 2007 04:10 AM
