Dr20's 10 degree offset on a del sol
Old Feb 20, 2012 | 09:02 PM
gokus-eg2's Avatar
Default Dr20's 10 degree offset on a del sol
I got someone wanting to trade their machined face gold 15" dr20 with like a 3" lip n 10 degree offset for my 16 drag slips....... Here's my problem I have about a sport line drop , I know those ***** hella pop out ... Are my front and rear fenders Gunna be hella rubbing ? Would I need to camber them in or flare out or jus roll my fenders to make emm fit with out lowering or raising my car anymore?
Old Feb 20, 2012 | 09:08 PM
speedooo's Avatar
Default Re: Dr20's 10 degree offset on a del sol
The entire poimt of wie wheels with stretched tires is to get the rim as close to the fender arch as possible. It's going to look horrible.
And for your education, offset is measured in mm, not degrees. Camber is a physical measurement of wheel tilt described in degrees.
Old Feb 20, 2012 | 09:14 PM
gokus-eg2's Avatar
My bad yea I don't know **** about suspension like that, but that's what I figured , Ill jus keep it the way it is
Old Feb 20, 2012 | 11:21 PM
98civdx's Avatar
Master Detailer
Tire size?
You will more then likely need, camber kits, tons of camber, rolled fenders, and ugly *** stretched tires, not to mention those are dangerous.
And drag slips? What are those?
Old Feb 21, 2012 | 04:43 AM
gokus-eg2's Avatar
Originally Posted by 98civdx
Tire size?
Tires are 205/45/15, I already have camber kits on, don't have rolled fenders, n yea I commute in that car so definitely don't need stretched tires
I jus call emm drag slips cuz theyr the same thing as Rota slipstreams but theyr the drag DR23
Old Feb 21, 2012 | 09:00 AM
98civdx's Avatar
Master Detailer
What size is the wheel? 15x???
marcelosm
Nov 24, 2014 07:58 AM
coryfenton
May 10, 2012 06:31 AM
dannythewonder
Honda S2000
Sep 20, 2010 11:19 AM
sheperd77
Apr 25, 2009 10:13 AM
2G0S0R1
Jan 14, 2002 09:15 PM
