fixed sensor on transmission but ....
Old Feb 20, 2012 | 02:33 PM
miguel11691's Avatar
Default fixed sensor on transmission but ....
The check engine light came on and the the car starting the jerk a lot and but continued to shift fine.... Now it doesn't shift and only drivable on D2 and I have to press down hard on the pedal to even reverse the car... What seems to be not working... Is it the torque converter or an engine problem... I have a 2002 honda accord ex with 131000 miles on it
Old Feb 25, 2012 | 07:24 PM
Default Re: fixed sensor on transmission but ....
Please help.. now the car doesnt wanna drive... revs up but nothing .... works for 20 minutes and after it just revs up
Old Feb 26, 2012 | 06:33 AM
Lost Again's Avatar
Check the fluid.
Check the codes.
Hope you are not one of the many with 98-02 Accord, where auto trans that gave/gives out.
Old Feb 28, 2012 | 10:22 PM
fubuallstar's Avatar
Check fluid and all connectors, Drain fluid from Tranny on the left (From front) its a circle with a 1/4 drive(ratchet without using a socket) slot rotate and fluid will come out take about 4 quarts out go to autozone get rislone http://www.barsproducts.com/catalog/...ak-repair-4502 i had similar problems i put quarter of rislone in followed by 2 qrts started moved thru gears then rest rislone followed by 1 n 1/2 qrt tranny fluid. let it run for a few minutes then moved thru gears took for spin and by the time i got at end of street i felt the life comeback to the tranny its been working for about 2years now no problems. its worth a shot and worked with my buddies civic also. P.S. Walmart sells import tranny fluid cheaper then autozone but gotta go to autozone for rislone. Hope this helps
Old Mar 5, 2012 | 05:38 AM
I bought the Bar's Leaks Transmission Repair will that be good.. Also where is the transmission dipstick at
Old Mar 5, 2012 | 10:59 PM
bottom of transmission in front its a yellow circle, im not to sure about what u bought i only recommend what i have used and had good results using
Old Mar 6, 2012 | 10:58 PM
MAD_MIKE's Avatar
MM Gruppe B
I would not put that in the transmission.
Are there any codes stored in the PCM?
da35apprentice
Apr 3, 2017 08:42 AM
NerfGunner420
Sep 27, 2014 12:02 AM
toolbox21
May 29, 2014 11:04 AM
Yuyodrift91
Aug 9, 2008 09:58 PM
xxpnoyballa543
Feb 7, 2008 06:52 PM
