few Q's about b-series parts
1st .. i have a b16a are the motor mounts for my car interchangeable for a b18b1 ?
2nd .. will my tranny work with that motor
3rd .. what if any wiring would be involved
car its going into .. 89si rex.. with b16a already in
i can't answer your question, but i'll tell ya this... u need to take out all that sound system crap, playstation 2 mess, and whatever else u had in there... strip it out, and track that sucker!
what kind of mounts are they? I believe the Place Racing mounts will interchange. I'm not too sure about any other mounts.
:edit: B16A tranny will work with the B18B, and no other wiring involved.
[Modified by Home Skillet, 12:32 AM 10/10/2002]
b series parts are just that.. b series parts.
with that in mind.. your B16a and B18 use the same mounts
wiring is same but you will have 4 extra plugs. vtec related if you put in the b18b. and only 3 left over plugs if the b18 has a knock sensor.. i'm not sure.
cool thanks for the info i figured that most of it could be interchangeable like the mounts *place racing* i wasnt to sure of my wiring harnest thats probably the hardest part of the swap im thinking about..
ps
ha the stereo stuff is coming out to be redone .. even if show cars are "Ghey"
[Modified by .:s h a w n D:., 7:01 AM 10/10/2002]
ps
The 90-93 B18a motors came with the same drivers side engine mount (motor side) as the 1st gen B16 like the one you already have in your CRX.
The B18b driver's side mount will need to be changed to the one like on your B16 to work in your chassis.
You can use your existing B-series kit (HaSport, Place, etc,.)
but if he has a 1st gen jdm b16, pre OBD, then wouldn't he have to have some changes to the wiring to run a 98 LS ecu and change it all to OBD-2. and the same for the dizzy and injectors, all non OBD now, it is a 98 integra LS that he is getting the stuff from.
hondasir1988
10
Apr 12, 2002 07:06 PM
