Braking trouble
Old Oct 9, 2002 | 07:56 PM
jb1813's Avatar
Default Braking trouble
Hey just a question looking for some help. When I brake my steering wheel has a slight shake that varies depending on the braking pressure I am using. Any thoughts on what could be causing this? Thanks
Old Oct 9, 2002 | 07:57 PM
mickey513's Avatar
Default Re: Braking trouble (jb1813)
Your rotors are most likely warped. Changed them or get them resurface.
Old Oct 9, 2002 | 08:08 PM
jb1813's Avatar
Default Re: Braking trouble (mickey513)
can you check your own rotors or is it necessary to take them to a shop to get them looked at or replaced?
Old Oct 9, 2002 | 08:45 PM
Tomakit's Avatar
the shudder under braking is pretty indicative of warped rotors.
how long have you had the rotors/pads on for?
Tom
Old Oct 9, 2002 | 10:38 PM
animated_life's Avatar
Default Re: Braking trouble (Tomakit)
yeah you can kind of check them. jack up the front of your car and take off your front wheels and stick your head in the wheel well right above the rotor and spin the wheel (while it's not in gear obviously) and look down at the top of the rotor. isn't in any way precise...but it will give you a rough estimate of whether you have some warped ***** or not. not too expensive to get them resurfaced or to just buy some new ones too.
Justin Meiring
Oct 14, 2014 08:41 AM
glulude
May 1, 2007 04:57 PM
AViciousTHRUST
Apr 2, 2006 08:30 AM
zseeanz
Mar 24, 2004 02:41 PM
tornactive.com
May 3, 2002 06:17 PM
