s40 b000 lsd
Old Feb 20, 2012 | 10:55 AM
svtford4x4's Avatar
Default s40 b000 lsd
looking into getting a lsd for winter driving as well as better handling while the trans is out. there's the cheap ebay lsd's was wondering what experiences people are having with them.
Old Feb 20, 2012 | 10:57 AM
svtford4x4's Avatar
Default Re: s40 b000 lsd
i read some mixed reviews, someone mentioned giving the castings a good once over and deburring before installing. any input on them would be good.
grumblemarc's Avatar
The Grumpiest
The words "cheap" "Ebay" should be your first warning. If you're talking about the OBX ones I heard they were hit and miss.
Old Feb 20, 2012 | 10:59 AM
svtford4x4's Avatar
obx was the main one i have heard of. they are in the 300$ range. yes i have heard allot of horror stories of cheap ebay stuff.
Old Feb 20, 2012 | 11:24 AM
Red_Army's Avatar
OEM LSD if you can find one.
quaife or wavetrac. for aftermarket.
IMO unless you have the bank for quaife/wavetrac finding an LSD tranny is probably your cheapest option.
Old Feb 20, 2012 | 11:27 AM
Libertariat's Avatar
Ek Forever y0!
If you're mechanically inclined, people have had success with the OBX LSD but you have to take it apart and reassemble it for it to work for longer than a month.
MFactory and Quaife are good too. I would recommend getting one of them instead.
Old Feb 20, 2012 | 12:46 PM
94EG8's Avatar
Seagull Management
the phantom slip ones you see on ebay for next to nothing do, well, next to nothing. It's an incomplete copy of someone else's design.
OBX is a really hit or miss, probably more often miss. Those bellville washers everyone talks about? They're just for noise suppression, nothing more. The whole problem with OBX is runout issues and improperly cast parts, and you just can't fix that stuff. If you get lucky and happen to get good one and replace the belville washers's they're fine, key word being if.
Mfactory makes some really nice units, that are reasonably priced for what you get.
Old Feb 20, 2012 | 07:14 PM
svtford4x4's Avatar
oh i didnt realize this had been covered so much i just googled obx lsd and it was the first link.
Old Feb 20, 2012 | 07:16 PM
svtford4x4's Avatar
is the bearing the only difference in b000 to a000 are differentials interchangeable?
Old Feb 20, 2012 | 07:17 PM
MySickSi's Avatar
I had an obx lsd in my gsr trans for about 8 months now, works like a charm
Old Feb 20, 2012 | 07:56 PM
svtford4x4's Avatar
I actually just picked up the transmission today it has allegedly 80k miles looks a little corroded from being in a basement. I plan to take it apart and inspect it as best as I can and replace seals, maybe isb. Doesn't look like i can afford a decent lsd so might not do it. mfactory looks like really good quality parts though.
Maybe i'll post in the "what's it worth" thread see if i made out on the transmission or not.
Old Feb 20, 2012 | 07:57 PM
svtford4x4's Avatar
i've read really mixed reviews on the obx, everyone says to really check it over before installing, but i'll be honest i am not 100% on what to look for.
Old Feb 20, 2012 | 08:01 PM
94EG8's Avatar
Seagull Management
No, the carrier is different too because of the bearings. If you want to use an A000 diff you need an A000 case too. (ring gears swap if you wanted to do this, but I don't know why you would)
Old Feb 20, 2012 | 09:17 PM
svtford4x4's Avatar
i was looking into it because of a cheap used lsd d series i found online but wanted to keep the b000 ratio.
94ludeking
Nov 7, 2011 06:56 AM
allnaturalb16
May 1, 2007 04:32 PM
wespirl
Nov 2, 2004 10:15 PM
