Transmission & Drivetrain Gearboxes, Differentials, Clutches
hydraulic ls trans differential question
Old Feb 20, 2012 | 08:58 AM
.all-motor+.eG8's Avatar
Default hydraulic ls trans differential question
i broke my diff. ive been searching but cant find anything on if i can fit a cable diff into my hydraulic trans. my current one is beyond repair about 2 or 3 pieces . thanks in advance. (i knew i should have bought the evo)
Edit: and is there a difference between auto and 5spd.
Old Feb 20, 2012 | 02:36 PM
94EG8's Avatar
Seagull Management
Default Re: hydraulic ls trans differential question
'92 - '93 Cable YS1 LS diff will work (I think GS-R will too actually) no other cable diff will work though.
Old Feb 20, 2012 | 06:04 PM
Honda Bull's Avatar
'92-'93 YS1 LS and GSR diffs are indeed the same. Only those will fit the 92-01 hydro transmissions.
Old Feb 22, 2012 | 09:23 PM
Antilag's Avatar
If he has a ls trans, a gsr fitment will not work. as the inside diameter hole of a gsr/ctr/itr is 116.8mm accross. A b16/ls is 109.8mm accross and yes if you have a lsd of a cable and its oem, it is a viscous and a 14 bolt, it will not work. But a b16/ls cable fitment will fit into your hydro trans.
Old Feb 23, 2012 | 03:33 AM
94EG8's Avatar
Seagull Management
The YS1 GS-R diff is the same as a B16A/LS diff. Hydro GS-R is different. The B17A1 tranny is almost the same as a B16A tranny.
sloK
Texas -OK -LA (Sales)
Jun 3, 2010 12:58 PM
cousin_ed
Sep 12, 2009 08:50 PM
import2nr88
Sep 25, 2008 02:07 AM
gutted-dx
Feb 26, 2007 11:49 AM
Absentmind
Jun 19, 2004 12:12 PM
