FS/FT: Honda/Acura Parts 88-00, MO
Trying to clean up some parts i have sitting around, all prices are picked up, i will ship smaller items or deliver(within reason) at your expense unless other wise negotiated.
I am PayPal certified.
Best way to contact me is through pm
All parts are located in southeast mo
~88-91~
Hatch exhaust oem complete from cat. to tip - $25
Rear drums brakes /w trailing arms (off 89 si, comes with prop valve) - $35
Crx dx headliner (no sunroof) - $30
Rear Bumper 88-89 (one white one black both paint is ruff) - $40ea.
90-91 Front red - $40
Headlights has some chips comes with brackets (2x l&r) - $20ea / $40pair
Crx Rear Side Plastics (x2 black, have some sun fading) - $15ea / $25pair
Crx Dash (dx, no cluster, a/c control) - make offer
d16a6 /w lsd trans (runs did not smoke leaks some oil from the pan seal,has low comp, pistons, aftermarket rods, adjustable cam gear, fpr, i do not know the miles on it, i have a receipt for the lsd,and install about $1,500) - make offer
Upper cross member bar (t-bracket, x3 black,gold,white) - $40
d15b2 bottom end (never ran it,spins freely, cylinders look good) - $50
88 dx 4spd trans (was told worked have not used) - $40
auto trans (came out of a hatch if shifted in and out of drive but the motor was shot so i have not driven it) - make offer
Side skirts (stock, x2) - $15ea / $20pair
Dual point intake manifold (x2, has all sensors)- $20ea
Pgmfi intake manifold (from a hf)- $25
Clutch cable (used, but work x2) - $10ea
~92-95~
Driver and pass glass (x2) - $30ea / $45pair
Rear Hatch glass - $50ea.
Rear Tailgate (white) - $30
Front bumper from a 4dr has been cut in back for i/c, red - $25
Headlights (have a couple chips, brackets good except corner light screw) (x2 sets) - $25ea / $40pair
Dash (i believe from a 94, and a 92, /w or w/o air bag, grey) (x2) - make offer
Headliner(non sunroof, cx model) - $40
Rear quarter glass (x2sets) - $30ea / $50pair
Pass mirror block off - $7
air bag (grey) - $35
wing (stock style white) - $20
steering column controls (ex:blinker,lights,wipers x2) - $40ea
grey center console (not perfect have a couple scratches, cup holder does not work, ebrake, shifter,lower dash portion) - $20all
grey glove box - $10
grey column cover - $5
grey lower dash cover - $5
washer reservoir - $8
hood latch (x2) - $10
Hood latch cable - $15
Trunk latch cable - $10
Passenger door handle (x2) - $15ea
Steering column with key - $50
Steering wheel (grey) - $10
Climate controls (x2) - $40ea
~96-00~
Si rear sway bar (no end links or brackets) - $40
Si style grill (fake carbon fiber) new - $25
Heater core and black surrounding case (from a 99) - $20
Si oem exhaust (no cat, cut at axle back) - $20
y8 vtec head (never ran it, no solenoid, dizzy, or intake manifold) - 120
d16y7 head (ran when pulled, did smoke a little in higher rpms) - $80
D16y7 bottom end (nothing but long block, crank, main caps, water pipe and oil pan) - $30
Dx intake manifold complete with all sensors - $20
-Integra_
DA headliner - $40
B18 ls auto trans. was told worked fine removed for a 5spd - $50
E brake cables (work fine, from a 94 rear disk) - $25ea / $40 both
~misc~-
Prelude auto ecu (worked when removed) - $30
Subaru oem turbo back exhaust(off a 02 wrx) - make offer
a/c lines from eg/ek (x20 assorted) - $10ea
Del sol seats (red stripe, have a couple holes and has had fabric repair) - $40
Will trade for: Black eg rear plastic, crx roll bar, crx skunk2 upper cntrl arms, crx aftermarket front shocks, paintball guns(no pumps, junk ect.),, guns, raptor parts,
If you would like a pic of anything let me know i will take one. Thanks
~88-91~
~92-95~
~96-00~
-Integra_
DA headliner - $40
~misc~-
By rear side plastics i mean the interior panels that cover the wheel well, they also cover the rear speakers. I am not willing to ship them they are to bulky i could not guarantee that they would arrive unharmed.
Could I get some pics of these items
CW-ITR
Northern California (Sales)
22
Apr 30, 2009 04:45 PM
CW-ITR
Aug 13, 2007 06:06 AM
FakeJDMEF8
Sep 26, 2006 07:04 PM
