Put it back together and now...97 Civic DX won't start
Old Feb 19, 2012 | 05:23 PM
Donkeylips87's Avatar
Default Put it back together and now...97 Civic DX won't start
Hello everyone,
We have a 97 Civic Coupe DX 5SPD with I/H/E.
I just completed the Y7/Y8 mini me. When I was doing it I also replaced the following:
Pistons and Rings with P2P
Timing Belt
All Acc. Belts
Rear Main Seal
Rod Bearings
Main Bearings
Head Gasket
Brand New Knock Sensor
AEM Tru Time Cam Gear
Fresh Hone for Cross Hatching.
ARP Head Studs
Clutch and Flywheel
All New Coolant Hoses
New Air Filter
Anyway, replaced a lot of stuff. Now the car won't start. I thought I had purchased a 5SPD OBDII P2P ECU. I found today that wasn't the case after attempting to start it and having no luck. I check the ECU code and it's for an A/T. FML. But, it should still start with the Y7 ECU. Just no VTEC. I have tried both the Y7 and Y8 dizzys with the Y7 P2E ECU. I am not getting spark. When I try to start it the speedo jumps all over the place. 80mph, 120mph, 30mph. I also get a clicking noise, like a relay going ape **** from the top right of the glove boxes. Also my CEL does not come on when I turn the key to ON.
Any help is much appreciated. Thanks,
Kurtis
Old Feb 19, 2012 | 05:36 PM
Former User's Avatar
Default Re: Put it back together and now...97 Civic DX won't start
A mystery title is a no-no in tech forums.
Thread titles MUST summarize the tech problem so that members browsing titles can easily understand the problem without reading the post -- Title edited.
Old Feb 19, 2012 | 05:38 PM
Does the fuel pump prime?
Is the G101 ground on the thermostat housing connected and tight?
Any blown fuses?
Old Feb 19, 2012 | 05:57 PM
Any blown fuses?
I knew it was a ground. I just couldn't remember which one. That was it. Still idles like crap but it will until I get the right ECU. Thanks.
Old Feb 19, 2012 | 06:04 PM
HondaPartsHero's Avatar
Technical Hero
Also did u convert to 2 wire IACV?
Old Feb 19, 2012 | 06:10 PM
Sure did.
91_e_f
Jun 9, 2010 10:22 AM
alexg103
Mar 16, 2010 09:46 AM
hondadx92
Aug 12, 2009 07:04 PM
slowassciv33
Nov 20, 2006 02:49 AM
96 EX
Dec 6, 2005 10:09 AM
