88 Honda Civic error 20
Old Feb 19, 2012 | 05:14 PM
avi4t's Avatar
Default 88 Honda Civic error 20
i have a Honda civic 88 automatic that gives a error code 20. i already tried replacing the main fuse box. the voltages are around were it should be(usually a volt less then it should be) but when i change the high/low beams on the car starts to die. while the beams are off the car runs but still lacks power on take off. i have similar symptoms like
http://www.automobile.hondaciviclx.c....php?p=3434683
has but he has an error 16, with mine it has 20. (my car isn't flooding.) when i go the speed i need it at, it could stay there, but still have problems with the beams. also had a speed sensor error code 17 for awhile, got these codes when i went 50 miles. Please help asap!!!!!I'm ready to strap a couple pounds of c4 to it and blow this car up.
Old Feb 19, 2012 | 06:26 PM
delsol92's Avatar
Default Re: 88 Honda Civic error 20
my crx did this, it was the altenator
Old Feb 19, 2012 | 06:48 PM
avi4t's Avatar
the alternator puts out 12 volts so it shouldn't be that.
Old Feb 20, 2012 | 05:50 AM
delsol92's Avatar
mine put out 14 volts but i changed it and it fixed the issue
Old Feb 20, 2012 | 11:58 AM
Barry116's Avatar
Alternators are supposed to put out between like 14 and 16
Yomara Cattoni
Honda Civic (2001 - 2005)
Oct 30, 2012 04:47 PM
BIJITHOMAS
Apr 13, 2007 12:57 PM
