91' SI Fuel Problems
Old Feb 19, 2012 | 02:14 PM
EFcivicguy's Avatar
Default 91' SI Fuel Problems
Ok so I am buying a 91' SI and before I can take it the guy wants to get it running. We believe its a fuel problem... so...
-We blew out the fuel lines
-changed the fuel filter
-changed the fuel pump
and we're not sure what the problem is now... any suggestions on what to do next?
Old Feb 19, 2012 | 03:13 PM
EFcivicguy's Avatar
Default Re: 91' SI Fuel Problems
Also, when the key is turned on, the fuel pump doesn't turn on like it should
Old Feb 19, 2012 | 04:55 PM
90civic-ZC's Avatar
try the main relay
Old Feb 19, 2012 | 06:29 PM
delsol92's Avatar
in my crx the fuel pump doesnt come on till the motor is actually turning over, cus with obd0 cars the injectors dont prime until they are told to
and they are told what to do by the distributor
Old Feb 19, 2012 | 07:59 PM
90civic-ZC's Avatar
Don't get affended dude, but whoever told you that is wrong. First off, the fuel pump always primes regaurdless what OBD you are....how do you think the fuel gets to the rail for start ups. And two, the distributor tells nothing to the injectors. The ecu controls the the injectors, by reading multiple of things in milli-seconds to spray the adequate fuel. P.O. I'd check the main relay and ignition switch.
Old Feb 20, 2012 | 04:57 AM
crvtectim's Avatar
Just testing out my new sig.
Old Feb 20, 2012 | 05:53 AM
delsol92's Avatar
if thats the case why cant you use an 0bd1 distributor with an obd0 ecu
Old Feb 20, 2012 | 07:08 AM
90civic-ZC's Avatar
Because one the plugs are different and two....I'll try to quote this as best as possible because I havent seen the movie in a while......how does a '75 Plymouth rear end work? It just does.
Old Feb 20, 2012 | 07:20 AM
Spug's Avatar
The wiring is different, and I think the OBD1 has a sensor or sensors that OBD0 doesn't use. Obviously the OBD1 ecu is meant to have the sensors that are in an OBD1 dizzy, as the OBD0 ecu isn't.
Old Feb 20, 2012 | 07:58 AM
delsol92's Avatar
now i see why everyone talks **** about you in other forums
Old Feb 20, 2012 | 08:03 AM
90civic-ZC's Avatar
HA! Whatever dude.....you cant even take a joke.
Old Feb 20, 2012 | 08:07 AM
90civic-ZC's Avatar
And Spug you're right.
Old Feb 20, 2012 | 02:15 PM
EFcivicguy's Avatar
Thank you to those who actually helped me.
Old Feb 20, 2012 | 02:19 PM
90civic-ZC's Avatar
Any luck OP? Could you give us a better discription of what's going on with the car?
Old Feb 20, 2012 | 04:01 PM
delsol92's Avatar
i tried to help from my experiences, cus on my crx if i take the distributor off and the fuel rail if i turn the little thing on my distributor my injectors squirt fuel
quartermilerun
20
Jul 8, 2017 09:24 AM
Cameron60
Jan 16, 2007 06:04 PM
shift6
Sep 7, 2004 09:39 PM
eg6_lsi
Mar 25, 2004 10:29 PM
