Del Sol Seats, B16 blocks, Stainless fuel line, B series flywheels
Pair of 1995 Honda Del Sol seats with red center, Driver side seat had small rip which is now stitched up. No stains or burn marks. Rails from EK civic included however these can be swapped for what ever rails you have off your old seats: $250
2 oem b series flywheels need to be resurfaced: $40 each
Aeromotive 11142 - 340lph Stealth Fuel Pump. Placed in my tank never ran. $150
Brand new Russell Stainless Fuel Line 92-95 Civic EX Si, Del Sol, Integra: $70
2X b16 blocks one comes with crank new crank bearings, oil + water pump, and various pieces and a turbo feed line. The other is the same but with no crank. Both blocks are bored for the 81.5 Supertech pistons I have for sale. one block has a golden eagle block guard and has no use on the new bore. The other block has a Supertech block guard and was used for 1300kms before tear down, also has golden eagle oil squiter plugs. $150 for block with crank, $100 without
DEI 1" Titanium Exhaust Header Heat Wrap enough to do a header or downpipe with. Design Engineering’s new Titanium Wrap, using LR Technology, is capable of handling direct continuous heat up to 1800 degrees F and radiant heat up to 2800 degrees F.: $30
poetikrime
Oct 15, 2008 12:46 PM
IgniteTeg
10
Sep 11, 2002 09:34 PM
