need a little help with piston choice
Old Feb 19, 2012 | 07:50 AM
keepinTHEh23's Avatar
Default need a little help with piston choice
I am getting ready to pull my engine to work on a few things and I figured while it was out i might upgrade my pistons. I have an h23 and I would like to run usdm h22 pistons not the type s pistons. I have heard it can be done but I would like to know what all needs to be done to run these pistons. There is a lot of controversy on whether or not there is enough clearance with an h23 head. I basically want to know if it can be done and what i need to buy/do to run these pistons. If it isn't really feasible I wont mess with it, because it works now.
Old Feb 19, 2012 | 11:33 AM
InvaderTrax's Avatar
Default Re: need a little help with piston choice
Shouldn't be any extra work needed
Old Feb 19, 2012 | 01:31 PM
snobordboy's Avatar
Moderator
They will stick out the hole .020, but the head gasket is .026, so as long as you run stock cams and nothing has been decked, you should be fine.
Old Feb 19, 2012 | 01:34 PM
SpokaneSpeed's Avatar
Keyword being "should". Don't take any chances. Check your clearances.
Old Feb 19, 2012 | 01:36 PM
Alright thanks for the help so ill check my clearances to make sure everything is good and hopefully install some h22 pistons
Dabrybry
Nov 6, 2008 10:31 AM
vteclude217
Sep 6, 2008 11:09 AM
krayzieboi213
Jan 24, 2008 09:13 AM
92silude
Mar 14, 2005 01:41 PM
user 9782082308
Dec 30, 2002 03:08 PM
