oil in my engine bay .. best way to clean ?
Old Feb 19, 2012 | 05:31 AM
street_ride14's Avatar
Default oil in my engine bay .. best way to clean ?
Valve cover gasket issue .. got oil all over my engine bay.
What is the best way to go about cleaning this mess ?
Old Feb 19, 2012 | 05:33 AM
grumblemarc's Avatar
The Grumpiest
Default Re: oil in my engine bay .. best way to clean ?
Brake cleaner.
Old Feb 19, 2012 | 07:37 AM
fcm's Avatar
fcm
Old Fart
Good quality degrease like Simple Green Extreme and a pressure washer and compressed air.
Best done on a cold engine, wet engine down, cover everything with Simple Green alow to sit for a bit, pressure wash off, repeat if needed, use compressed air to "dry" off the engine, don't forget to pull the spark plug leads and blow any water out from the spark plug wells. 94
Old Feb 19, 2012 | 07:31 PM
riverrunner06's Avatar
From: recentlty moved out from under the rock and into a spacious dumpster :O)
Simple Green works... Purple power kicks a$$ on cleaning oil and grease! Best on warm (not hot) engine, spray it on and let it soak a few minutes then pressure wash or use a pressure nozzle on your garden hose. Repeating this process if needed or desired cleaner results. Be careful to limit exposure to this stuff as it is a mild acid and will dry your skin to the point of causing cracking. Not nice on the nose or eyes either.
Old Feb 21, 2012 | 08:07 PM
10psiLsEf2's Avatar
purple power FTW!
becarefull not to get it on finished metals! like a intAKE tube or on the top of a SKUNK 2 pro manifold! it tends to leave it DULL
Old Feb 21, 2012 | 08:19 PM
turbohatch96y7's Avatar
There's a cleaner called RMC the best stuff I ever used if you can find it use it you will never remeber another cleaning agent after I promise.
Here's another secrret for really tuff thick grease use wd40 or any penetrating lubricant the grease slides right off.
Don't wet your battery or alternator. Don't wet a hot head/or header.
Clorox works too.
Old Feb 22, 2012 | 05:43 AM
tron_'s Avatar
10 Year Member
If you do use simple green, be careful around any unprotected aluminum. It will etch.
rhdekhatchie
Nov 25, 2008 05:37 PM
JJeg67
35
Dec 3, 2007 07:19 AM
jlh22179tx
10
Mar 11, 2007 05:53 PM
EF-9SiR
Mar 10, 2003 04:56 PM
wessieball
Apr 22, 2002 01:02 PM
