Suspension & Brakes Theory, alignment, spring rates....
Clunking noise driving me nuts!
Old Feb 19, 2012 | 04:17 AM
mr_munro's Avatar
Default Clunking noise driving me nuts!
2001 DC2R
Tein SS Suspension
Whiteline Rear Sway bar.
2.5" Fujitsubu Catback.
Clunking noise coming from the rear of my car. Happens when i go over some bumps and have recently discovered that when i go up ramps on an angle there is a popping sound.
At first i thought it was something in the boot....but i took out EVERYTHING and it is still there. I even jacked the car up, took the wheels off and put them back on nice and tight...still there! So i have a feeling it is my suspension somewhere. I have a feeling it may be my sway bar or sway bar endlinks. When i jacked the car up i couldnt see anything that could cause such a clunking noise, unless the swaybar moves when the car bounces up and down and possibly hit the chassis?
Anyone else experience this problem? If it is the swaybar endlinks, any ideas on how to fix it?
Thanks!
Old Feb 19, 2012 | 08:08 AM
98civdx's Avatar
Master Detailer
Default Re: Clunking noise driving me nuts!
What endlinks do you have?
My blox sphericals make a ton of noise.
Old Feb 19, 2012 | 08:09 AM
mr_munro's Avatar
Not quite sure, maybe whiteline endlinks? Swaybar was on there when i got the car...Ill get pics tomo.
Old Feb 19, 2012 | 08:15 AM
98civdx's Avatar
Master Detailer
If they are adjustble the noise is most likely coming from them.
It they look to be adjustble, unbolt them and take the car for a spin and see if the noise continues.
Old Feb 19, 2012 | 08:18 AM
mr_munro's Avatar
The swaybar itself is adjustible:
"PRODUCT BENEFITS
This Whiteline 24mm 2 point adjustable swaybar = more grip = better handling = outright performance - it's the best dollar for dollar handling improvement you can make to your vehicle. This Whiteline adjustable sway bar allows its rate to be altered by increasing or reducing the length of the lever arms. This permits the roll stiffness to be tuned for different situations without replacing the entire bar. The stiffer the bar, the more force required to move the left and right wheels relative to each other. This increases the amount of force required to make the body roll"
Ok, ill take them off and see how the car drives..thanks
Old Feb 19, 2012 | 07:25 PM
mr_munro's Avatar
pics added! I dont seem to have any endlinks? :S
i also noticed in this image, the end of the sway bar doesnt seem to be connected to anything and i can move it up and down a fair bit within the bushing...is it not suppose to be joined to anything?
Old Feb 19, 2012 | 07:39 PM
98civdx's Avatar
Master Detailer
In the first post, the second picture. Shouldn't the endlink bolt be there?
You don't have them?
Can you take a picture of the front of the LCA? That would be really funny if you didn't have them. But, the search for the noise goes on.
Old Feb 19, 2012 | 08:01 PM
mr_munro's Avatar
ok first pic is the front of the LCA, is that the endlink? (passenger side) and the second pic...err think i found my problem...isnt that suppoe to be attached lol? , this would explain the movement in the swaybar?
Old Feb 19, 2012 | 08:15 PM
98civdx's Avatar
Master Detailer
Yeah, that is the endlink, and yes, that is a broken endlink.
And that appears to be a leaking Tein coilover.
Old Feb 19, 2012 | 08:17 PM
mr_munro's Avatar
Any idea where i can purchase another? Does it look like an OEM endlink?
mr_munro's Avatar
That would just be lube i sprayed on it for when i was height adjusting it
Old Feb 19, 2012 | 08:20 PM
98civdx's Avatar
Master Detailer
It does look like a OEM endlink, however, I would contact a whiteline dealer and ask what endlink they reccomend using with that bar. If it is a OE type, you should be able to pick up a OEM endlink.
Old Feb 19, 2012 | 08:27 PM
mr_munro's Avatar
No worries, will do. Thanks for your help. Ill update the problem. Gawd i hope this is what is causing the noise.
Old Feb 19, 2012 | 08:31 PM
98civdx's Avatar
Master Detailer
Yep.
I'm interested to here the end result.
Old Feb 19, 2012 | 08:39 PM
mr_munro's Avatar
Yep.
Just a matter of when whiteline get back to me. In the meantime i found these
http://www.velocityshop.com/product/...ype-r_137.html
and i would be paying as much for the shipping as the item because i am in Australia
Old Feb 19, 2012 | 08:50 PM
98civdx's Avatar
Master Detailer
No dealers in your area?
Hardrace makes good products.
Old Feb 19, 2012 | 08:56 PM
mr_munro's Avatar
Well i emailed Whiteline and they came back to me with
"Hi ,
Sorry we do not have links for this model
Fantastic....
Old Feb 19, 2012 | 09:15 PM
98civdx's Avatar
Master Detailer
hmm. I guess ask them if they reccomend using OEM type endlinks.
Old Feb 19, 2012 | 09:43 PM
mr_munro's Avatar
I think i will just purchase the hardrace, but for that price and they don't fix the noise i will be seriously pissed off
Old Feb 19, 2012 | 10:13 PM
98civdx's Avatar
Master Detailer
Yeah. lol That is why I would just jump and order them.
Spending 100+ on endlinks that might not work would suck.
Old Feb 19, 2012 | 11:28 PM
mr_munro's Avatar
Im going to take teh swaybar off in the next couple of days and report back to see if they noise has gone, that way i am 100% sure it is teh swaybar
Old Feb 20, 2012 | 09:43 PM
mr_munro's Avatar
well the swaybar is off and the noise is gone...it is going to stay off until i get another endlink so i gotta be careful how i corner in the meantime
Old Feb 20, 2012 | 11:17 PM
98civdx's Avatar
Master Detailer
Old Feb 21, 2012 | 03:43 PM
mr_munro's Avatar
Originally Posted by solbrothers
I love when OPs aren't retarded and we help them and everything works out
hahaha i would'nt count on it yet! I found some genuine endlinks from Honda wreckers (still $46 each) so wont know for sure the broken endlink is responsible for the sound until i put it on! Stay tuned!
Old Feb 23, 2012 | 09:07 PM
mr_munro's Avatar
Update:
Found a dealer in my area that sell hardrace endlinks and i got them at a discounted price! Will hopefully install them both tonight and will see if the clunking noise is gone!
