b18c to ef7 crx
Old Feb 18, 2012 | 11:22 PM
standy xsi's Avatar
Default b18c to ef7 crx
wat do i need to swap
wat i have...
dc2 b18c complete car
ef7 crx
p30 ecu and 0bd0 harness installed in crx
da drive shafts
da shift linkage
hassport mounts
Old Feb 19, 2012 | 04:47 AM
Deetz's Avatar
Crazy Honda Guy
Default Re: b18c to ef7 crx
You will need to chip your p30 ecu for the b18
You will need a cable to hydro conversion for the transmission
Some wiring is needed to add vtec and the electronic speed sensor unless you want to use the older cable stye
You need to shorten that DA shift linkage
You need a DA engine post mount
Old Feb 19, 2012 | 11:04 AM
standy xsi's Avatar
wat bowt puting the p72 ecu in. will the obdo harness plug in?
i also have jdm ys1 lsd and a j1 gearbox can i use one of them an bolt it right up?
JeffBro
14
Aug 27, 2010 11:59 AM
luvcivics
20
May 21, 2010 07:19 PM
project crx
Jul 7, 2006 10:02 PM
bruce500
May 1, 2004 07:21 PM
dohcdelsol
Sep 14, 2003 08:10 AM
