EF Sedan Cluster fit in EF Hatch? (Sedan as Tacmeter or whatever)
So I was at the Junkyard today and got a few items. I found a Si Hatch there same year as mine and swipped ALOT of stuff off it. But I passed a EF Sedan and knew that the Cluster had a Tacmeter on it (I'm not sure if that's what it's called, but the gauge that reads the revs). My hatch doesn't have that so I thought I'd swip it.
Will it fit?
Also, do I need to add a harness for the new Cluster to work since their different?
Thanks!
Will it fit?
Thanks!
yes it will fit, most if not all EF parts are interchangible(sp?) between that generation of vehicle
the new cluster you got should be plug and play, but you may have to run a wire for the tachometer part, (Google & Youtube are your best friends for that)
