Custom gauge advice?
Old Feb 18, 2012 | 12:56 PM
Barry116's Avatar
Default Custom gauge advice?
I have a 1989 Civic hatch with a b18c and im thinking about replacing and adding gauges with probably auto meter gauges for a more custom look. any adivce or info on any aspect of this anyone?
Old Feb 18, 2012 | 05:16 PM
90civic-ZC's Avatar
Default Re: Custom gauge advice?
Why don't you just keep you're tach and add a stoich meter and oil pressure then be done with it......Or are you looking to do more?
Old Feb 18, 2012 | 05:49 PM
Barry116's Avatar
Id like to do more cause my gauge cluster is a little beat as it is and my tach redlines at 5k when the motor does at i believe after 7k
Old Feb 18, 2012 | 05:51 PM
Red-Rocket's Avatar
just replace your gauge cluster with an EF civic Si cluster, should be plug and play, for extra gauges if you have the cash go for autometer and mount them in the din under your climate control
Old Feb 18, 2012 | 06:43 PM
Barry116's Avatar
I have the Si cluster i believe but it didnt fit right and there was no tach, it came in the car when i bought it
Old Feb 18, 2012 | 07:19 PM
///Mathew's Avatar
The si cluster comes with a tach. The not fitting right might have been due to the fact that the 88-89 and 90-91 clusters are a different shape.
Old Feb 18, 2012 | 07:21 PM
Red-Rocket's Avatar
all Si clusters came with a tachometer built in, if you can't find an 88-91 gauge cluster you like. then buy a decent tachometer and wire it up,
G. Man
Classic Hondas
Oct 20, 2011 07:26 PM
stockcivic103
Jun 25, 2006 12:07 AM
hondahustle
12
Jun 15, 2006 01:09 AM
DWHONDA
Jun 2, 2006 06:06 PM
pK1spooled
13
Sep 27, 2004 03:01 PM
