blockguard ?
Old Feb 18, 2012 | 04:25 AM
Rickcrx's Avatar
Default blockguard ?
Im about to pick up a b18c1 block and is bore to 81.5mm, hone, decked and hot tank and also they installed a block guard. i dont like block guard cus all the problems might happen so i wanted kno if i can pull the guard off and the sleeve beein ok with no distortions.
Old Feb 18, 2012 | 05:38 AM
trickeng's Avatar
Default Re: blockguard ?
It is very unlikely there will not be excessive rebound from the blockguard being pounded in. BUT, if the blockguard can be pulled out with very little effort you should be fine.
Old Feb 23, 2012 | 05:18 PM
Glorymanunited's Avatar
No need block guard. just take it out...unless u bore it until 84mm then u might consider a block guard. cheers.
eg:R
Apr 19, 2014 08:56 AM
jspeedy
Mar 18, 2004 06:49 PM
Soon_2b_evil
Aug 8, 2003 06:40 PM
