92-95 EJ struts on a 99 EJ
Ballin on a budget o'er here. Looked at the junk yards listings. They seem to have a ton more 92-95's than 96-00's and I'm considering using those struts if I can find a set that's in better condition than a set off a 96-00. Will they fit?
The rear shocks have a wider shock fork on the '92 - '95 Civics/'94 - '01 Integras so you need to use a couple of washers on each side for spacers, you'll also need the longer '92 - '95 Bolts that go through the rear shocks.
Honestly I wouldn't go hunting for junkyard shocks. New KYB GR2s aren't that much new. Of course of you happen to find a set of like new junkyard shocks dirt cheap there's nothing wrong with that.
SL!M
Aug 27, 2003 02:12 PM
