Clutch/high idle
Old Oct 9, 2002 | 05:52 PM
snoop_bealybob's Avatar
Default Clutch/high idle
Ok this Accord I got to fix up ismoving right along. Fixed the turn switch today, now lights go up and down too. Next thing...
Clutch seems fine when you first start the car up and drive doesn't slip, but sometimes well not let me out of first or reverse. Is this a clutch cable that needs to be adjusted? This also seems worse once I've driven the car for about ten minutes (once it's warmed up).
Also, in the end of my little trip around the neigborhood today the idle went back up to 2000rpms when I put it in neutral. It usually is cold at a loud 2000rpms but drops to 1500 and then 900-1000 after a few minutes. So I was wondering what could bring the idle back up like that after it has been warmed up and driven a bit?
It seems that maybe it's corelated with the clutch somehow, but I don't know anything about clutches or transmissions.
Thanks in advance for your answer(s).
1986 Accord
213k
Carb engine
5spd.
Old Oct 9, 2002 | 10:17 PM
Default Re: Clutch/high idle (onetym408)
I have heard a high hissing sound that I thought might be a seperate issue, that I was going to investigate tomorrow. It's right under the carb somewhere but tought to locate I think without taking the air cleaner off.
Thanks.
Anyone on the clutch question???
lsvtek
17
Feb 26, 2011 06:22 PM
brian323is
Mar 15, 2010 11:17 AM
skata89
Apr 6, 2007 08:39 AM
sin2k5
Oct 1, 2006 03:50 PM
