95 Accord LX Bucking
Old Feb 16, 2012 | 04:01 PM
po_snake's Avatar
Default 95 Accord LX Bucking
My 95 Accord LX bucks after the engine has idled and warmed. Once the engine is warm and RPM the drops to the normal RPM, the sound of the engine changes and the car runs rich 12-13 AFR then it goes back to 14.7. If I drive the car after this happens the car bucks at light throttle (due to running lean) and if I apply more throttle it runs fine. The problem is intermittent and goes away if I stop and let the car idle for a minute or two. Plugs and wires have been replaced I'm leaning toward the IACV or clogged EGR ports. Any help would be greatly appreciated.
Old Feb 16, 2012 | 06:09 PM
kidcool1977's Avatar
SHAME ON YOU REBECCA!
Community Builder
Default Re: 95 Accord LX Bucking
I hate these issues because I am having them myself but my car was fine before I replaced the dizzy and did the timing belt.
As for your issue have you properly gaped your spark plugs, is your timing on point. Your fuel filter could be clogged, your cat could be clogged or you may have a vacuum leak and there are so many variables to this issue it hurts my head.
Since you assume it's the EGR ports or IAC start with that.
Did this issue randomly pop up out of the blue?
Old Feb 17, 2012 | 02:01 AM
po_snake's Avatar
The problem just started recently and I'm not getting any error codes.
Old Feb 17, 2012 | 10:49 PM
holmesnmanny's Avatar
Since this appears to be related to the egr system since it only happens when the car is warmed up I would clean out the ports and egr valve first.
Mohit_narain
Nov 3, 2018 09:27 AM
Ntense_Civic
Apr 20, 2012 04:47 PM
menoride
Dec 11, 2007 06:30 AM
lowsinthe20s
Aug 23, 2006 09:49 PM
TOMSBLUEHONDA23
Aug 1, 2005 03:02 AM
