Oil leak?
Old Feb 16, 2012 | 12:53 PM
num1_tuner's Avatar
Icon3 Oil leak?
Hello everyone I have an oil leak on a 90' accord and I thought it might have been the oil pan gasket that was leaking. But after fixing that issue, I found right next to it between the oil pan and the (what I believe) water pump, it is leaking also. I just need to make sure that is the water pump there so I can get the right gasket if thats what it is. Or if anyone else has other ideas, I'd appreciate them. I am unfamiliar with Hondas and have never come across this problem before.
Thanks for any help
Old Feb 16, 2012 | 09:22 PM
nus_dogg's Avatar
Default Re: Oil leak?
Maybe the oil pump may need to be reseal.
Old Feb 16, 2012 | 09:25 PM
epicoliver's Avatar
had oil leak myself the other day, '92 civic, after replacing the oil pressure switch/sensor leak was gone. the part was 10 dollars at the local auto parts store and took a whole ten to twenty minutes to clean up the area and put new part in. its located right above the oil filter on my honda, probably similar on your accord.
Thanks for any help
VenomRx
Dec 18, 2013 11:58 AM
MumBleZ_94gsR
May 30, 2009 03:26 PM
Quickridez_3
May 1, 2008 12:17 AM
tw1nny03
Mar 3, 2008 05:29 AM
PearlWhiteAccord
Dec 17, 2002 09:48 AM
