93 Del sol w/OBD2 B18 swap radiator hose part #?
Hi All,
It's been a while but I FINALLY got my GSR w/LSD and getting some parts to prep. for the swap.
- Timing belt
- in/out radiator hoses
I need to know which hoses I need that will fit b18/b16?
Also, what other parts would I need for the swap?
I already have a wiring harness that I got with the swap which I think was the biggie.
Thanks all,
Jon
- Timing belt
Thanks all,
Jon
aftermarket clutch
spark plugs/wires
water pump
valve cover gasket kit
P72 (OBD1) ecu
both axles
** DOHC VTEC Del Sol shift linkage ** <---- you will need this!!!
If you are going to replace both radiator hoses, get one for a "DOHC VTEC Del Sol or SI coupe (99-00)".
spark plugs/wires
water pump
P72 (OBD1) ecu
both axles
I have the ECU and axles that came with the swap already and forgot about the valve cover gasket
-Jon
It's wayyy easier to replace the clutch, water pump and timing belt with the engine out in the open. Don't forget to replace the front AND rear main seal as well. Using Genuine Honda parts is your best bet. You can thank me later.
Shawn Bryan
Jun 17, 2017 09:42 AM
91tegrals
Nov 12, 2007 07:43 PM
Hockey27925
May 19, 2004 05:50 AM
