EJ6 B16 Swap
Hey guys, i want to apologize in advance for asking a question that has probably been beaten to death, but i could not find any info with an hour on google so here it is:
I'm looking into swapping a b16 engine and transmission into my 1996 civic cx (5spd)
Im curious what all i will require or need to modify such as wiring hanrness and axles etc. Hopefully someone that has done this swap before can offer some pointers.
Thanks.
Thanks.
well if you get the full swap it will come with the harness and ecu, you will need mounts,T-bracket, shift linkage, now if i were you, once you have the motor replace the timing belt water pump plugs wires every gasket on the engine, clutch all fluids. Now you have it easier cause you have a little more of a choice when it comes to swap choices cause the b16 came in a 96-98 and you can get the whole swap from hmo w.o having to worry about jumper harnesses or what not. You should be able to use em1 mounts and linkage as well hope this helps a little bit
