95 LX - shudder when under load at idle
Old Feb 15, 2012 | 12:48 PM
silum2k6's Avatar
Default 95 LX - shudder when under load at idle
Buying a 95 Accord lx with non-vtec engine.
It idles ok, but when the rear defrost, AC, power steering, or any other heavy mechanical/electrical load is placed on the engine, it will drop in RPM and shudder pretty badly.
It does have a bad engine mount, but I'm more concerned about the drop in rpm. I think if I clean the TB out, and the IAC, would be a good start, then move to plugs/wires, and maybe timing belt, since it needs it anyway...
It has 162k on it, and it's never had basic maint done to it...but I'm getting it for cheeeaaapp....
any insight would be great...I just want to see what I'm in for...I also work at a dealer, but I don't always trust a tech first hand...lol
Old Feb 15, 2012 | 12:52 PM
holmesnmanny's Avatar
Default Re: 95 LX - shudder when under load at idle
Originally Posted by silum2k6
I think if I clean the IAC, would be a good start,
Start with that. Look at the sticky in the FAQ's for Cleaning the IACV.
Old Feb 15, 2012 | 12:57 PM
silum2k6's Avatar
Thanks man...I'll give it the ol college try :D
Old Feb 18, 2012 | 07:52 AM
rival12's Avatar
Consider changing the mount.
Old Feb 20, 2012 | 10:48 PM
bob441's Avatar
Clean the egr ports It's real easy,Get a can of chemtool b12(makes job easier)Take the three bolts off fuel rail remove fuel rail( you do not have to remove fuel lines ) remove the five bolts on the plate below the injectors,clean out the holes pull the plate apart and clean it real good also
Old Feb 21, 2012 | 06:27 AM
silum2k6's Avatar
cool thanks, we replaced the motor mount, that helped a good bit, but I think with a little make up maint. she will be great!
bantis
16
Jun 17, 2012 12:55 PM
po_snake
Feb 17, 2012 10:49 PM
graffini
Jan 31, 2010 10:59 AM
OzzieAccord
May 22, 2006 10:13 PM
slowexcoupe
Apr 24, 2006 04:34 AM
