Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
I drove like a madman around an off ramp, then my car cut off and got code P2646
Old Feb 15, 2012 | 11:56 AM
theLemur's Avatar
Default I drove like a madman around an off ramp, then my car cut off and got code P2646
I have a 2004 4cyl 5 speed accord. I beat the living crap out of it. Can this car really not handle an offramp and maximum speed? It was understeering the whole time, tires screeching, and when I got out of the loop the car put some rev limiter in place at like 3000 rpm and would shut down the throttle completely if I hit it. Weird...
Old Feb 15, 2012 | 12:05 PM
MSchu's Avatar
My Name is Nobody
Default Re: I drove like a madman around an off ramp, then my car cut off and got code P2646
very weird
Old Feb 15, 2012 | 02:50 PM
theLemur's Avatar
I should mention that this code was for oil pressure, so I guess we can't take accords around corners
Old Feb 15, 2012 | 05:56 PM
MSchu's Avatar
My Name is Nobody
wow
Old Feb 15, 2012 | 07:19 PM
D-JET's Avatar
P2646 - VTEC Oil Pressure Switch Circuit Low Voltage.
Check oil level.
Old Feb 18, 2012 | 08:27 AM
justinsbg's Avatar
This code usually stores due to a faulty vtec pressure switch or a low oil pressure situation. Have you had your oil changed recently? If so, does your engine have the proper oil level? How many miles are on your car?
Old Feb 20, 2012 | 08:47 AM
motegicivic's Avatar
Don't forget the oil level could of been low plus the hard cornering could of shifted the oil in the pan and temp starved the oil pump, sounds extreme but you never know.
Jeff Liller
Honda CR-V & Element
Mar 6, 2018 04:25 PM
VTechYo
Jan 25, 2014 12:16 AM
Keith_B
Jun 22, 2009 01:14 PM
