Lighting HID/Xenon kits, Retrofits and Associated Topics
Bright 1156 led bulbs?
Old Feb 15, 2012 | 11:28 AM
96DelSol's Avatar
Default Bright 1156 led bulbs?
Hey guys I need some bright led bulbs in 1156 size.
They are for the factory aux lights on a del sol.
Which do you guys recommend? They turn on when headlights are on.
Old Feb 29, 2012 | 08:35 PM
96DelSol's Avatar
Default Re: Bright 1156 led bulbs?
Your right aux light suck, Im gonna do a retrofit onto my jdm one pieces thanks boss
Old Mar 1, 2012 | 02:31 PM
TunerN00b's Avatar
Originally Posted by solbrothers
get EDM fogs. the del sol aux lights are a joke. completely useless
EDM glass aux actually do something
also get some JDM/edm(i believe) lower fogs as well
A good idea except for a few issues:
1) That isn't legal in the US. Too many lamps up front.
2) Those lower fog lamps are too low to provide any useful light.
OP, retrofit a set of blazer fog lamps into the stock aux lamp housings. Good output, clean cutoff, HID capable without glare.
Old Mar 4, 2012 | 06:59 PM
j-r_rida's Avatar
well idk about your first statement... alot of cars have three sets of lights in the front that come stock from the factory....
Old Mar 5, 2012 | 10:16 AM
TunerN00b's Avatar
That's 4 lamps total now.
A car is allowed:
headlamps
highbeam lamps, if separate from the mains
marker lamps
supplementary lamps
That Del Sol has 2 sets of supplementary lamps, which is why it is illegal. The corner lamps are the front marker lamps, and I'm guessing those are what you're forgetting to count.
Old Mar 7, 2012 | 02:20 PM
dumafit's Avatar
http://automationled.bigcartel.com/p...-back-up-bulbs
it's listed under back up light but you can use it in the aux for the del sol
Old Mar 9, 2012 | 01:31 PM
White95SiHB's Avatar
TunerN00b, I was under the impression that only 2 sets of lights can be turned on? So even though that particular del Sol has the aux lamps and fog lamps, as long as only one of those is turned on with the head lamps it's OK?
I disagree with your statement about those fog lamps being too low to be useful. I've had foglights that low before that, when aimed properly, can provide enough light that I could get by with them should my headlights ever burn out.
Old Mar 9, 2012 | 01:55 PM
TunerN00b's Avatar
Mostly correct. 3 sets of lamps can be turned on. A pair of primary lamps, a pair of supplemental lamps (fog or additional headlamps), and a pair of marker lamps. 2 sets have to be on at night, the primaries and markers.
So, yes, as long as only 1 of the 2 sets of the additional lamps are on it would be legal. But, if you're only going to use one set, why add more lamps that low in the bumper instead of replacing the set it came with?
And I stand behind saying they're too low. Lamps that low, aimed at the legal angle, would only project light 15', at most, in front of the car. Now, if they are incorrectly aimed higher (such as aimed level), then they could, but would also pose a glare issue.
Old Mar 9, 2012 | 02:40 PM
Well for me, the only ones that put out useful light were Stanleys and Depos for 94-97 Integras and 92-95 Civics, respectively.
Universal fog lamps (Piaa, Pilot, etc.) I noticed just plain sucked at any height.
Old Mar 16, 2012 | 10:21 PM
0zker's Avatar
if you want some bright reverse 1156 led's get these...
http://www.ebay.com/itm/2x-White-115...ht_3001wt_1070
have had them for over 6 months in my ej1 and haven't had a problem with them. i have spent hundreds on led's and trust me when i say that these things are insanely bright. i LOVE them!! they aren't meant to stay on for a prolong time but your car is only put in reverse seconds at a time..
Old Mar 22, 2012 | 02:14 PM
96DelSol's Avatar
tried those, made no difference, i ended up retrofiting my headlights with bixenon projectors, I can see now
NVMYSi
15
Mar 27, 2021 08:37 AM
509delsol
Apr 25, 2011 09:06 AM
Bryro22
Lighting
Mar 4, 2009 08:55 AM
Rafl.H
Lighting
Aug 2, 2008 07:52 PM
BrysonIsAScammer
Oct 31, 2004 12:19 PM
